Question about Philips 60PP9352 60" Rear Projection Television
Power up problem
Have Phillips 60" that will not turn on. Checked power at wall socket and it's fine. Unit is three years old. Help!!!
  • GarrisonSch Nov 28, 2007
    I have the exact same problem. This is the third time it's happened. Best Buy usually comes out to fix it and it's just some sort of reset thing. Hoewever, my warranty has expired. If anyone has any idea what I can do myself please help out!
It has donehis to me a few times. I have unplugged all power bars plugs and replugged. Worked the few times it happened to me. Leave them out for a minutes or so too.
Posted on Aug 30, 2007
SOURCE:
All 3 handsets seem to be dead at same time. It seems odd that they would all go out at same time. Is it simply a battery issue? The answering machine part works fine.
Check the line using an old conventional plug in phone. You should always keep one for power cuts. Also, get someone to phone your number.
One a three handset system, the signal to all three are driven by the main unit, the bit with the answering system. Check that is plugged in to the mains wall socket and if it is, check for power at the socket. If that checks out, you need to check that little plug in power supply unit. Best way is with a test meter. If the lights are on on the unit and the answer machine works, then you know you have power at that unit, so you need to check the power supplies in the slave units.
My guess is that your line is dead to the house.
Dec 23, 2015 | Lands Phones
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
The monitor is a Dell? UltaSharp 2007WFP 20.1 Inch Flat Panel Monitor. I Tried everything. different power cables, DVI cables, VGA cables, disconnecting everything and reconnecting. NOTHING WORKS. I even...
Not sure if this is your problem, but I have seen this with another Dell monitor on three separate occasions. The solution I found was to turn off at the wall power socket, unplug at the wall socket, plug back in, turn on at socket etc and everything was fine. Guess something hangs up somewhere.
Dec 08, 2010 | Dell Computers & Internet
My sister gave us a Phillips tv from her house and before it was moved over here it was working fine. Now when we try to plug it in it sparks from the plug and will not turn on at all. What's wrong with...
Hi, I believe that there must be high voltage passing from that wall socket. Kindly try in different wall sockets. But i highly recommend that you take it to a nearby technician as its not easy for us to fix it.
Please take care. Thank you :)
Nov 02, 2010 | Philips Magnavox 9P6034C 60" Rear...
My maytag electric dryer has worked perfectly fine for 10 years. today i unplugged the dryer and did some work on the wall. when i plugged the dryer back in it tripped the breaker. could it be the dryer or...
You already unpluged before the wall work, so the problem is isolated from the dryer from its plug. Take off the wall socket to inspect since it may have damaged. If you have the voltmeter, measure each pair of the terminal. they should have a voltage at least 110V since it is three-phase voltage. If there is no voltage then just replace the socket. Make sure to turn main power off when you do the replacement.
Apr 27, 2010 | Whirlpool LER5636P Electric Dryer
My dishe washer wont turn on
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced
Now, if you have confirmed that the unit is receiving power from the outlet, and the unit is still not responding, this will lead to a failed control board, or timer module. replace either the timer, or control board, in this case.
Nov 05, 2009 | Dishwashers
Maytag Dishwasher MDBH965AW will not power.
If the junction box checks out ok, the wall outlet socket is live, replace the main control or timer module.
Jun 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
Mar 10, 2008 | Philips 60PP9352 60" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
