Question about Pine Technology XFX GeForce 7950GT, (512 MB) PCI Express Graphic Card
My monitor no longer shows anything due to my nvidia driver malfunctioning or something. How do i fix this with no monitor?
    Problem Solver:
  • 5 Answers
You will need to switch out the card for a different one, or if your mobo has onboard graphics, remove the card and run on that.
Posted on Jan 07, 2009
Al2032w
This usually indicates that the filter capacitors in the power supply are not working right. When the unit is turned on they should build up a charge that lets the board power up the monitor but when they start to go out it takes longer and longer to get the charge built up. Here is a link to information on rebuilding the power supply board by replacing the capacitors, this should get you back up and running.
www.ccl-la.com/catalog/product_info.php?products_id=288
Dec 08, 2012 | Acer AL2216WBD LCD Monitor
No longer able to access higher video resolutions
Have you tried removing the card and replacing it in a different slot which should get the computer to automatically find the card and the right drivers.
Barry
Nov 26, 2012 | Dell Alienware Computers & Internet
AMD ATHLON 2800 XP PROCESSOR, (using XP Pro, Svc Pk 3). NVIDIA GeForce 4 MX graphics w/64 MB DDR. Red no longer shows. Checked monitor so that is not the problem. I assume it has something to do with the...
The integrated graphics may have bit the dust.. but I'd suspect a poor connection at the jack first. Try disconnecting the cable from the PC (and the monitor if not molded in) and reseat the plug(s) into the jack(s). Give it a wiggle and see if you can detect the red channel coming on. Check the VGA cable for signs of damage. If unable to get the red, you'll need to isolate the trouble to either a faulty graphics port or monitor. You can do that by swapping the monitor with a known good one OR installing a VGA card in an open slot of the MB. A third possible swap would be for the VGA cable if it can be separated from the monitor.
You may have to change a setting in the BIOS to tell the computer to use the PCI or AGP video if you go the expansion card route tho. Swapping the monitor shouldn't be a problem if you change the resolution in the OS to match the new monitor (or simply set to VGA) so that you don't over drive the replacement monitor.
Either of these two methods will provide you with a definitive answer as to the health of the monitor or graphics adapter. Just remember to change ONE thing at a time - don't make two changes at the same time as you won't know which is the faulty component.
I hope this helps!
May 20, 2010 | AMD Athlon-64 2800 CPU and Mother Board...
My samsung(syncmaster 500s) monitor shows poor colours when connected to vaio laptop(XP home, nvidia geforce6200). how can i fix? could it be drivers?
yes it is drivers problem the drivers of laptop are not matching with monitor but you also try another on that laptop if persist then vga connector of the monitor is faulty
Mar 07, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Second monitor detected but no signal?!
Try holding the function key ( fn) and pushing the F4 button. This very well may fix your problem.
Sep 22, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Getting my display on my nvidia geforce mx420 to show on my tv???
Make sure you have the new drivers from nVidia and then go to windows and get the latest DirectX 9.0 or above drivers.
Mastersage...........
Feb 17, 2009 | Dell Dimension 4550 PC Desktop
Can't get picture back on lap top after connecting to ext monitor
Hello there. You sound very frustrated. try this, go into your BIOS settings and cycle the settings for your vga adapter, or even reseting the options to basic performance. also, you could hook up the external monitor and disable it while it's hooked up. that should fix any problems with that(if you still have an extra.)
Nov 11, 2008 | Nvidia Computers & Internet
Xerox XA7 19" 1028x1024 resolution not possible with Nvidia Vista drivers for 8800gs
Well, if you say you have the latest drivers availble from NVIDIA, have you tried updating the driver for the monitor itself? http://www.xerox-displays.info/driver/XEROX_XA7_DRIVER/XEROX_XA7_DRIVER.zip (the device is in device manager under Monitors i believe) Well aside from that you'll just might have to wait for an updated video card driver! Another question, what is the max resolution that is available on your pc? regards, babb
May 02, 2007 | Xerox XA7-192i 19" LCD Monitor
540n screen is bright white
Due to it is new monitor the best way to solve problem is to take monitor back to seller and afterclaim it. Malfunction is inside monitor and you are not able to fix it.
Good luck
Dec 11, 2006 | Samsung SyncMaster 152N 15" LCD Monitor
Pine Technology XFX  GeForce  7950GT, (512 MB) PCI Express Graphic Card Logo
70 people viewed this question
Top Pine Technology Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
Alun Cox
Jerry Umali
Are you a Pine Technology Computer and Internet Expert? Answer questions, earn points and help others
