Question about Tech Solution TS-4500 Shredder
Shredder Problem The paper sensor switch on my Tech Solutions TS4500 is not working properly. In order to get the paper to shred, I have to press the switch all the way in with a pencil while the paper is being shredded. Is there anyway to fix this? Thanks.
  • 8 more comments
  • gassed Dec 07, 2007
    We can not get shredder to shred in pulling in paper, must reverse switch and then push to forward will shred a page in about three tries. Have not attempted to fix but ready to trash.
  • Fife Dec 09, 2007
    Same problem as above two. I've tried to take the thing apart, but it WON'T come apart.
  • Gary de Sesa Feb 28, 2008
    Yes, replace the paper sensor switch. But how? Is there some contact information for the company or for repair?
  • Anonymous Feb 28, 2008
    Shredder will not shred. Shredder jammed and when I put shredder into reverse it stopped working. If I push in the switch on the underside the machine works in forward and for a few seconds in reverse. Is there any way to keep the switch on? Tech Solution TS-4500 Paper Shredde
    Jacquie
  • JPJOHNNY May 04, 2008
    As it turns out, tonight I found there is a SEVENTH screw in order to get at everything. The screw on my unit was hidden under the serial number decal. I did not know it was there, so out of frustration an dnot being able to get things apart to unjam them of paper shreds, I muscled it apart, and in the process broke the on/off switch, yada yada.
    Trying to take it apart, beware the hidden screw under decal.
  • Anonymous Jul 14, 2008
    the shredder works only in reverse.
    the interlock switch is working.
    the problem seems to be the paper sensor
  • retiredtucso Aug 10, 2008
    Same problem. The start trigger has to be pushed with something thick to activate it. Up to five sheets won't activate it.
  • cdur2110 Oct 20, 2008
    I have the same problem, only I use an old kitchen knife to press in the paper sensor..........
  • Anonymous Feb 07, 2009
    Only works in reverse
  • orders3314 Apr 22, 2009
    Where can I get a paper sensor switch or find someone who can replace it. I haven't had success finding the Tech Solution web site.
Replace the paper sensor switch
Posted on May 28, 2007
SOURCE:
My Tech Solutions TS4500 paper shredder will shred approximately 1/2 page of one or several sheets of paper. But at that point it chokes and will not shred any further. It will back the unshred portion...
My experience has been that when a shredder chokes it usually is trying to tell you the bin is full but a cross-cut shredder is less susceptible. I do have a heavy duty cross-cut shredder that gets rather wonky when suffering from indigestion. Check whether the amount of bin content is affecting yours.
Jul 14, 2017 | Winsource Tech Solutions TS-4500 Cross-Cut...
Tech Solutions shredder Only powers in reverse w/ green light
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 01, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
My shredder keeps running and won't stop in on/auto mode
UNPLUG THE SHREDDER.
If this model has electronic eyes (optics) to control the auto-start/stop function and you oil the cutters, chances are the optics are contaminated with shredder oil. Take a cotton swab with a little alchohol and clean and dry the optics.
If you removed the top cover, it is a possibility that you disconnected the wires from the PC Board.
Mar 01, 2009 | Royal VF1012mx Shredder
Need wiring diagram/info for Tech Solutions TS2550 Paper Shredder
Thank you so very much for going into so much detail about my shredder that wouldn't pull paper thru it. You were SO NICE to do all that & I sincerely wish I could send you a picture of the wiring. HOWEVER, I threw it away months ago when I got no answer to my problem. Guess I'm not patient enough :-) I sincerely appreciate your reply and wish that I could help you out. If I still had it, I'd just mail it to you :-)
SWALynn
Jan 03, 2009 | Tech Solution TS-2550 Shredder
It sounds like you may have a gear with a broken tooth you should contact the manufacturer to get more info. Usually when this is the case it will shred good for only a few revolutions and then reversing backs the gear up to a position that allows it to turn the cutters until it once again reaches the area where tooth is missing.
Mar 11, 2008 | Winsource Tech Solutions TS-4500 Cross-Cut...
Paper shredder
The only solution with respect to safety is to order a new switch from the companuy that manufactures/sells this shredder, and mount it according to the manufacturer/sales company's instructions.
If you want to bypass the safety of the machine, just keep the cables (should be 2, + eventually a ground cable) open, or shorted, depending of the machine's configuration. Remember that this is on your or your collegaues own risk!! A shredder can easily bite your finger off!
May 19, 2007 | Tech Solution TS-4500 Shredder
TS4500 Shredder
there is one screw under the s/n sticker
May 08, 2007 | Tech Solution TS-4500 Shredder
Does the shredder have the electronic eye to sense paper? Sometimes dust will collect on the sensor causing it to keep running.
Apr 07, 2007 | Tech Solution TS-4500 Shredder
Tech Solution TS-4500 Shredder Logo
764 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Damen Wong
Damen Wong
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
