Question about Copystar CS-1510 Copier
The add toner light stays on with a new toner cartridge
Copier will only copy one at a time
  • jmatth1005 Apr 16, 2009
    The add toner light stays on and will NOT make multiple copies. It will make a single copy but need it to make multiples. Replacement Toner Cartridge was ordered from Staples and fits perfectly. Is there any diagnostic that can be ran or reset procedure?
    Problem Solver:
  • 12 Answers
Yes, the machine will only make single copies if the toner light is on. Was the toner cart genuine Copystar? Or perhaps Kyocera cart? The machine is made by Kyocera and marketed under both name brands, however, the toner carts are different for both machines. I have seen many times that aftermarket carts will not always work properly.
Posted on Jan 06, 2009
4 Suggested Answers
  • 653 Answers
SOURCE: studio 230 added a new toner cartridge
When adding toner to the developer unit, it will load from the toner. So, if toner is empty, it will ask for replacement. Normally u can hear noise from the toner when loading.
Posted on Mar 19, 2009
firecontrol7
  • 6674 Answers
SOURCE: Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Posted on Jul 13, 2009
firecontrol7
  • 6674 Answers
SOURCE: Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Posted on Jul 25, 2009
We bought a new cartridge for our AL-1631 copier. Up until the time we installed the new cartridge, we never had a problem with this copier. Now the copier indicator light is telling us that it needs a...
Sounds just like an empty cartridge. There is a bar with a long spring on it inside the toner cartridge. As the machine tries to add toner the bar "scrapes" the toner while stirring it in order to ensure all the toner is used. When the chamber is empty or near empty you can hear the spring making more or less a thump thump kind of noise about every 5 seconds or so. If this sounds like the noise you are hearing then it sounds like the toner chamber is empty. Did you buy this cartridge locally? If so you may be able to return it. Was it refilled? Remanufactured? or was it in a OEM Sharp Box with AL100TD or similar on the box? It sounds like either you got a bad/empty cartridge or the only onther possibility is, and I actually had a customer do this once, was accidentally put the old one back it the machine. Pulled the old one out. Unboxed the new one and somehow slid the old one back in. Worst thing was they threw the "new" cartridge away and by the time the light came on again it was long gone!
Good Luck and Thank You for using Fixya.
Oct 09, 2010 | Sharp AL-1641CS Laser Digital Copier
Ricoh 4220 copier. I replaced toner cartridge and
I suggest removing the toner, and visually inspecting it, make sure the sealing tab has been removed, give it a really good shake, as the toner may have settled in storage. re-insert the cartridge making sure it goes in the right way.
If you can hear a slight 'clicking' noise it's adding toner and pumping it into the developer unit, some machines take 2 minutes, some take 6..
Failing that, lift the platen cover and do a few black copies, so you force the machine to add toner.
Goodluck.
Oct 16, 2009 | Ricoh FT3713 Copier
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
Jun 18, 2009 | Konica Minolta Office Equipment & Supplies
How do I add toner to machine? Also, is this copier do color copies?
1 Open the front cover and pull out the
drum unit and toner cartridge assembly.
2 Hold down the lock lever on the left and
pull the toner cartridge out of the drum
unit.
3 Unpack the new toner cartridge. Place
the used toner cartridge into the
aluminum bag and discard it according
to local regulations.
4 Gently rock the toner cartridge from side
to side five or six times to distribute the
toner evenly inside the cartridge.
5 Remove the protective cover.
6 Insert the new toner cartridge in the
drum unit until it clicks into place. If you
put it in properly, the lock lever will lift
automatically.
7 Clean the primary corona wire inside the
drum unit by gently sliding the blue tab
from right to left several times. Return
the blue tab to the Home position (▼)
before reinstalling the drum unit and
8 Install the drum unit and toner cartridge
assembly in the MFC.
9 Close the front cover.
If you need illustration for this, click on the link below and turn to page 112
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Jun 02, 2009 | Brother MFC-7820N All-In-One Laser Printer
No error message but copier light doesn't come or number of copies doesn't work
let it run eventually the toner lite will come on, sharp copiers will run an extended period trying to add toner to the developer. developer is 70% iron filings and 30% toner as it uses the toner it cycles more in to stay at the proper level.
Apr 14, 2009 | Office Equipment & Supplies
Studio 230 added a new toner cartridge
Mar 19, 2009 | Office Equipment & Supplies
Toshiba 2860 Plain paper copier
It maybe the waste toner container is full try emptying it
Feb 19, 2008 | Toshiba 2860 Copier
Copystar CS-1510 Copier Logo
388 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
