Question about HP Officejet J5780 All-In-One InkJet Printer
I am having problems when printing out a copy from my computer.
The print on the copy is not clear. It is smeared and shadowed. What is wrong and what should I do?
    Genius:
  • 1,605 Answers
If run your figure across the print, does the print smear?
if os, yu need a new heater element, if no check the roller for dirt and print smear.
Posted on Jan 06, 2009
Top of the page prints fine. From the middle down it prints but also has a shadow or smear of what was printed higher up on the document.
there is a problem in fuser assembly where your prints actually fuses it needs to be cleaned or may need some parts to change
Jan 26, 2011 | HP LaserJet 2100 Printer
Problems printing. My print copies have cyan tone printed down the right side of each sheet. It look like the toner was actually smeared on the page and then baked on.
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 28, 2010 | HP LaserJet 2840 Printer
All letters are smeared. print not clear. shadowing affect.
try doing a drum refresh... if its a copier or ... if its a printer then replace drum and fuser... fuser is yellow or orange rollers in the back...
Dec 31, 2009 | Computers & Internet
Copy is not clear
Hi
The first thing you must check is the small scanner glass,this is the narrow glass that the machine is using when you use the dockfeeder,clean that glass and make sure there is no back dots on the glass.Even a small dot can cause lines on your page.But this lines will only be sen if you using the docfeeder.
The second probem can be the drum cartridge that is faulty.With this problem all your copies and printed pages will have lines.
If your drum is ok,the next thing that goes wrong is the fixing assy.
Jan 23, 2009 | Canon imageCLASS D320 Digital Copier
Lexmark Optra SC1275 printer smears
Looks like a problem with the laser unit or the drum unit or both, which may have to be replace. The website is correct. Best call for service.
Nov 13, 2008 | Lexmark E320 Laser Printer
SMEARED PRINTING ON RIGHT-SIDE MARGIN
Ist I take it you have replace the toner/drum. If not do so. If you have then check the paper path to make sure there is nothing in the way, like a torn piece of paper or a label stuck in there? If you are 100% positive the paper path is clear there maybe something stuck in the fusing unit.
Feb 11, 2008 | HP LaserJet 3030 All-In-One Printer
HP Printer problem
Sounds as though one of the drum cleaning blades is failing.
When you see the double image shadow, is it any particular color? If so, that's the drum unit that is failing.
Feb 06, 2008 | HP Color LaserJet 2600n Printer
SHADOWING
On a Dell3100cn changing the paper setting to covers2 helps.
Here is how I understand the problem:
The heating element does not always get hot enough and the toner gets smeared before is is fixed (in the photographic sense). Changing the paper type to covers2 increase the temp of the heating element eliminating the smearing.
Jan 21, 2008 | Dell 3100cn Laser Printer
Canon Multipass F80 printing problem
My canon F80 copies smear. How do I fix that?
Nov 07, 2007 | Canon MultiPASS F80 All-In-One InkJet...
HP Officejet J5780 All-In-One InkJet Printer Logo
141 people viewed this question
Ben Johnson
