Question about Dell 942 All-In-One InkJet Printer
I have a 942 all-in-one and need to install the blk ink cartridge. Please tell me how to do this.
    Novelist:
  • 140 Answers
Well if you have never done this I hope you do have a user manual because it makes it simpler to explain. The first part of the manual would show you a picture step by step on how to do this. But if you do not have one it is not difficult. First you need to power the printer off. Lift the lid so that you have access to where the printer head goes back and forth to print. Once you have lifted the lid the printer head and cartridges on it should be to the far left. You can reach with your fingers and gently pull it to the middle of the platen or carriage so you have it right in front of you. The cartridges are clearly marked and you simply have to lift the black ink cartridge out. They kind of snap into place so it may take a gentle pull to lift it up and back to get out. Take your new one and be sure you have taken a small cover they put on all of them off before snapping it back into place. When you pull the old one off you will be able to see the little cover I am talking about. Close the lid and power the printer back up and you are back in business. Good luck and God bless.
Posted on Jan 08, 2009
Dell 942 printer cycles on and off repeatally after installing new ink cartridge
Are the new cartridges from Dell?
I would try cleaning the contacts on the printer. Use a Q-tip and some isopropyl alchohol and clean the copper contacts where you cartridge plugs in. While your at it you might as well clean the copper contacts on the cartridge also. It is very common that Dell cartridges have this error. If that doesn't work send them back to Dell.
Nov 11, 2010 | Dell 942 All-In-One InkJet Printer
I bought a ink cartridge for my dell 942 printer. The box at staples says its for a 942 (it's the "offical" dell ink) but when I try to install it, it won't "snap" into place.
compare your old 942 cartridge with the one you just bought, if they're the same type then try putting the cartridge again, make sure that you have taken out the sticker on the cartridge copper contacts then put it in the right way. otherwise, have the cartridge replaced by the store you bought it from or contact Dell tech support and have them do the replacement.
Mar 18, 2010 | Dell 924 All-in-One InkJet Printer
Installed new color ink cartridge and printer still says "install a color ink cartridge on the right side"
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 08, 2010 | Dell 942 All-In-One InkJet Printer
Dell 942 AIO printer won't recognise black cartridge:
I think you purchased a black cartridge with bad electronics. Basically your cartridge can't communicate with your printer and you should exchange it for a new one. There is no way to "fool" your printer into accepting refills with bad electronics. What you can do is when you get the message that you aren't using genuine cartridges and it won't be able to estimate ink levels is to check the box indicating to ignore the ink levels.
Nov 13, 2009 | Dell 942 All-In-One InkJet Printer
Dell AIO 942 Error 2200
I would recommend cleaning off the contacts where the cartridge is loaded as well as the any other spots to see if maybe there is just something on the contacts.
Sep 19, 2009 | Dell 942 All-In-One InkJet Printer
Installed new blk ink cartridge and it tells me to install a new one. will not print as a consequence
call kodak @ 1800 421 6699 and they will replace the cartridge for you free of cost, if this does not solve the issue, bet with me your printer has Gone bad. Keep your fingers crossed.
Jul 29, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Display shows: printer cartridge incorrect
It seems like you are using incorrect printer cartridges.....
Make sure that part number on ink cartridges should be :
MK990 Cartridge, Ink, Standard, Series-9, Black CTRG,INK,STD,SERIES-9,BLK 0 1 0 Yes 1 N MK991 Cartridge, Ink, Standard, Series-9, Color CTRG,INK,STD,SERIES-9,CLR 0 1 0 Yes 1 N MK992 Cartridge, Ink, High-Yield, Series-9, Black CTRG,INK,HIYLD,SERIES-9,BLK 0 1 0 Yes 1 N MK993 Cartridge, Ink, High-Yield, Series-9, Color CTRG,INK,HIYLD,SERIES-9,CLR 0 1 0 Yes 1 N MK995 Cartridge, Ink, Series-9, Photo
Nov 10, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell 942 all-in-one printer problems.
The problem is simple. Try inserting your old in cartridges. If the old ones work, the ink cartridges are defective. Contact Dell and get these replaced.
Otherwise the printer has a problem. try cleaning the metal contacts of the ink cartridge and the ink carrier.
Sep 19, 2007 | Dell 942 All-In-One InkJet Printer
Dell 942 AIO printer cartridge problem
Was your replacement cartridge a new dell product? If it was, the sensor on the prnter should recognize it as new and reset the indicator to full. If, however, the cartridge was refilled, remanufactured, or otherwise an off brand, the ink indicator will show it to be empty. Just ignore and use the printer as normal -- it will print just fine, but you may need to press the select button to get it to start printing the first page.
Aug 26, 2007 | Dell 942 All-In-One InkJet Printer
Dell 942 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
