Question about HP Media Center m1180n PC Desktop
I got hp pavilion pc the problem is its not switching on there is a green light back of the pc it keep flashing what i ve to do My HP Pavillion will not come on and the green light at the back keeps flashing
  • Anonymous Jan 07, 2009
    I had this problem for somewhile where the fans would start running when I switched the PC on but no signal would appear on the monitor. It sometimes took several reboots to get the PC started. On top of that, after 10-15 mins, if I did not actively use the PC it would go into standby / hibernation mode. When I re-activated it, I would again lose the signal to the monitor and I would have to reboot again maybe several times.
    Over the last couple of days, the PC has stopped doing anything aside from a flashing green power indicator. Any idea where I go from here?
  • 28 Answers
If your network cable is plugged in it will flash green .....if it won't turn on pull the plug and wait 10 seconds or more then plug in again and see if it will start .....are the fans running and no signal to monitor?
Posted on Jan 07, 2009
  • Terry Shackleton
    Terry Shackleton Jan 07, 2009
    A new power supply may be in order ....Where your plug from wall plugs into the back of computer ...if you are willing to take the side cover off the computer and can get a good look at the mainboard (motherboard ) Check to see if there are any Capacitors that are bulging on the top ...they are the round cylinder looking things ...if there are some bulging instead of flat on top then the mainboard is going and needs to be replaced ....they can cause all kinds of wierd problems on the computer ...if they are all good then maby try a new power supply to see if that fixes the problem .
    hope that helps
Blinking green light on hp pavillion elite m9426f
If it's plugged in, getting power, a good place to start would be a PSU. Take a look at HP Support for more info: http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c01570954#N52
Apr 10, 2013 | HP Pavilion Elite m9426f Desktop
HP Pavilion a1020n will not power on.
The green LED light at the back of the Power Supply, is now a diagnostic LED light.
Tells you the Power Supply is bad.
HP Support > Pavilion a1020n Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=459880&lc=en&cc=us&dlc=en&lang=en&cc=us
Solve a problem > Start-up / Shutdown / Power >
(No Thanks) > Power management,
Scroll down. Click on the + sign to the left of the blue -
Power supply light is on or flashes
(When the PC worked the green light stayed on constantly. You are correct)
Now,...
1) Is the computer dirty inside? Need to know how to properly clean it?
2) Would you like to know the easy test, to see if the problem may be a $5 ATX power on switch, or the Power Supply?
3) I also suggest you remove all ram memory modules, ('Stick'), and clean their gold plated contact pins, with an eraser.
There is a proper procedure for this.
Post in a Comment if you wish to know.
Regards,
joecoolvette
{By the by. Did you or your father live in K.C.K, (USA), and does the name Philip B., ring a bell? }
Jul 02, 2012 | Computers & Internet
My hp pavillion mx 50 montior dosent turn on and if it does the green light on turns to an orange what to do to fix it
Check your Monitor Cable at the back of your PC unplug it and chec for bad pin conection make sure your Monitor cable are plug in correclty....
Oct 01, 2010 | HP Pavilion MX50 15" CRT Monitor
Bestec model atx 250 12z flashes green when hp pavilion a706n is powered on light on back blinks green and pc does not power on even after all cables are disconnected
Try these suggestions:
<a href="http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&cc=us&lc=en&dlc=en&product=427167&dlc=en&lang=en#bph06788_section_2" >Troubleshooting Power Supply Issues</a>
Nov 29, 2009 | HP Pavilion a706n PC Desktop
HP Pavilion A520N will not power up. Green light
Which light?? the network light?? Do you get anything when you press the power button if not it is most likely the power supply since the motherborad is still showing power also may be cpu!
Nov 17, 2009 | HP Pavilion A520n (DW233A#ABA) PC Desktop
I got an hp pavilion dv6000 and it won't turn on,
Try unpluging it then take the battery out then replace it after 30 seconds and plug it back in.
Oct 28, 2009 | HP Pavilion dv6000z Notebook
I have an HP Pavilion a384x. It will not turn on
First with the computer turned off make sure the switch on the power supply is set to 115v.
If you turn the computer back on and you still get a flashing green light on the back of the power supply and a constant light on the front of the computer with no video, then try replacing the power supply with either a new one or a known working good one.
If that doesn't do it then it has to be the motherboard at that point.
Keep in mind normally on those power supplies, the green light should be constant. So it has to be either the power supply is bad or the moterboard is bad and you'll know when you put a new or known good working power supply in the computer.
Aug 03, 2009 | HP Computers & Internet
Computer will not turn on
Posible bad power supply try using another power supply.
Jul 03, 2009 | HP Pavilion a620n (PC028A) PC Desktop
I have a hp pavillion f1723 but it wont switch on, the green led power light keeps flashing, what does this mean?
count the times the green led flashes? and how it flashes that´s an error code for your problem. it can be the motherboard or power.
Aug 13, 2008 | HP Computers & Internet
HP Media Center m1180n  PC Desktop Logo
273 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
