Question about Sansui COM3101 13" TV/VCR
On screen message "DEW"
The screen is displaying a message "DEW" I do not know waht this means and I can't get it to turn off It seem the remote has trouble progarming tv stations with this message on the screen
  • Sansui Master
  • 520 Answers
DEW on the screen means that there is moisture in set. Leave the unit on for several in a warm dry place. The heat from the picture tube will help dry out the set.
Posted on Jan 07, 2009
Whot does it mean when dew on screen and turns off just after
"Dew" means there is condensation (moisture) in the camera. The camera may refuse to operate until it is thoroughly dried out.
Nov 29, 2010 | E.Digital Sharp VL-Z5E Digital Viewcam...
Harmony 880 display is backlit but menu won't display. It seems to still work (pressing the button I know to be "Watch TV" turns everything on ok). Is the LCD broken?
Sometimes the LCD screen fails on the 880/890 series. But, there are a few tricks you can try that have brought the LCD back to life.
Some LCD problems have been solved by updating the remote's firmware while the remote has been placed in 'safe mode'. To do this, launch the Logitech Remote software on your computer and click on "Downloads" (on the top menu bar). Then, take the battery out of your remote and at the same time you connect the USB cable to your remote (it should be already connected on the computer end) press and hold down the Off button at the top of the remote. This will put the remote in "safe mode". Continue to hold down the Off button until you see the message "safe mode requested" on the remote's screen and the screen starts blinking. Now, since your screen is not behaving properly, you may or may not see this message, but after about 5 seconds you can release the Off button. Now, go back to your computer and click on "Firmware". If the software is able to communicate with the remote, an update to the remote's firmware should be executed. This has solved many a 'blue screen of death' problem. Good luck!
Feb 27, 2010 | Logitech Harmony 880 LCD Remote Control
Bypassing dew sensor on a Sharp VL-Z7 mini DV
- the solder joints to the DEW Sensor were "cold joints" which means that the solder joint is defective - is not a sound joint. This means that with temperature variation, the solder joint can intermittently separate and break the circuit, causing the DEW Indicator to come on and completely shut down the camera. The first problem I had with the camera was on a cold day, so it seemed to make sense.
Here is a picture from the perspective of the tape cover being at the top of the picture and the rest of the camera at the bottom. The dew sensor will be on your left.
go to:
http://omlets.tripod.com/sharpdew.jpg
Then, get a real slim soldering iron with a fine point. Open the tape cover and take the tape out. Get a strong light to shine down into the mechanism.
If your camera is like mine was, you may see a brownish material on or around the solder joint - this is flux used in soldering which was applied too heavily, and not heated long enough to burn off. The joint therefore doesn't quite connect the dew sensor to the terminal post - depending upon heat/cold ambient conditions, sometimes it makes contact and sometimes it doesn't .
Heat up the soldering iron - make certain the point is tinned (has a thin film of solder on it). Carefully just touch each solder joint for a couple of seconds - just enough for it to melt, and then quickly remove the soldering iron. You don't want to leave the iron in contact with the solder too long or it may melt other insulation around the terminal. This all probably sounds more complicated than it really is - but it really is just a 5 minute operation. If you've not done much soldering, and feel uncomfortable about trying it, you may want to take it to a radio, tv or computer repair shop and ask them to do it for you.
Jan 25, 2009 | Sharp Viewcam VL-Z7U Mini DV Digital...
Shut down "dew"
This happens when you take camera from cold(er) environment to warmer environment, dew forms on the recording head, so as a precaution the unit locks up. The solutions is to leave the unit switched on and wait till the dew incator goes out( can take up to an hour) I found this out when on holiday, i would go from an air conditioned room to bright sunshine and it happened all the time.
Sep 28, 2008 | JVC Everio GZ-MG30 Camcorder
DEW DETECTED / EJECT TAPE
I know that this sounds odd but the fix is to remove the battery and hit the camcorder on the back (where the battery was) with the palm or your hand. Put the batter back and it will work. I found this soluation a a CNET web site solution. I don't know why it works.
Jun 05, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Warning Dew Detected
Where are you keeping that camera? I would return this camera if it keeps happening (before warranty expire).
May 14, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Dew
It is possible that the dew sensor is faulty or more likely that the connection from teh sensor to the rest of the camera is faulty. This unit will require repair. If you can soler, you may be able to resolve this. I'll look up your model to see how bad the access is to the sensor.
Dan
May 13, 2008 | Sharp VL-Z800U Mini DV Digital Camcorder
No display on playback
Try first a Tape cleaner and a new cassette and start from scratch... and check if your camera is not damaged internally and it is actually recording and not just spining the tape to the end and rewind to find nothing on it. You seem to need serious repair. This means it needs a tech to have a serious look at it.
Feb 09, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
E007 and DEW indicator
Few restarts fixed this for me but I know this is going to come back again soon.
Mar 30, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sansui COM3101 13" TV/VCR Logo
172 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
