Question about Sony Boom Box With CD Player & Cassette Recorder,CFD-S01CD Radio/Cassette/CD Boombox
I need information on how to operate a tape in my machine. I can insert the tape, and push the button to start it playing, but the tape does not play. Which of the 6 buttons will get the tape to play?
My solution was to get my son to e-mail me the list of instructions that I couldn't find with my machine. The instructions, although vague, were very helpful!
Posted on Jan 07, 2009
How do I load the tape
I see your picture of a cassette player. Guess you are referring to that. (tapes also come in reel-to-reel, and 8-track). Just push the "EJECT" button (power may need to be applied to some units for the eject button to work). The tape slot will open. Insert tape with exposed tape on the "head" side of the opening, usually the heads are on the bottom of the slot.. You can't put it in any other way and have the door close. The "door" that opens has guides for you to slide the tape into. The side you want to listen to should face you. Either manually close the tape compartment or push the close button (depending on model). If the door doesn't close, you put it in upside down. Push play and enjoy.
Oct 01, 2014 | Audio Players & Recorders
Error message "push the reset switch"
Pull the battery out to reset it. Get a DV tape cleaner to clean out the tape deck.
That should solve both.
Aug 20, 2008 | Panasonic PV-GS300 Mini DV Digital...
Stuck video tape
Is the tape protection guard rotated upward (and the tape engaged with the heads)?
Aug 13, 2008 | Emerson EWV403 VHS VCR
Why will the Pioneer RT 707 not work in playback mode?
No it is the same motor for both functions. Just check does the record/play switch operate or move when you operate the record function? I have a hunch that is the problem it may also be that the switch contacts are dirty or worn.Try to play a recording you made on another machine if it does sound and play on the other machine then the problem can only be this switch. Some more upstairs decks do have separate amplifiers for play and record .Nakamichi. Studer Revox Tandberg Uher and the such comes to mind These are those machines offering "Off tape" recording monitor. Then it will sport three heads and not only two I hope this gives clues where to start looking for problems
Sep 01, 2014 | Audio Players & Recorders
When I place a tape in my Onkyo Integra TA2047 before I press any buttons it makes a humming noise. The reverse and FF work fine but when I push the Play button it starts rolling then slowly stops. I...
It can be a number of things. There are some models that are suppose to run the capstan when a tape is in and some unit that only run when the play is pushed. The proper operation and speed as well as cleaning can all be done by a Tape Deck Technician.
Aug 23, 2013 | Onkyo Audio Players & Recorders
VHS Tape won't stay in compartment
Going to have to look inside but expect to find that tape is not going all the way into position and having the tape pulled out and up against the drum with the video heads.
If it does not fully load a transport problem exists--drive idler and or belts.
Faintly possible also is something that does not belong inside got in past the door and is jamming it up.
Apr 24, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
My camera says please reoperate after pushing reset button
rear operation unit must be replaced,problem in flat cable inside it
Jun 27, 2009 | Panasonic NV-DS38 Mini DV Digital...
NEED HELP
G'day,
I also have the same problem and after almost buying a replacement I thought I would try one time to get it to go.
What I did was start the cam without a tape in it, let it bring up the little red icon indicating no tape inserted, (it hadn't started flashing "PLEASE RE-OPERATE AFTER PUSHING RESET BUTTON" at this stage) then I inserted my tape. Hey presto, it works although for how long I don't know. I'll immediately start burn my tapes to disc while the going is good.
Hope this helps someone
Aug 22, 2008 | Panasonic NV-DS38 Mini DV Digital...
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Sony Boom Box With CD Player & Cassette Recorder,CFD-S01CD Radio/Cassette/CD Boombox Logo
184 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
