Question about Amana ACS3350AS Gas Kitchen Range
AMANA acs3350AS We need to replace the black mylar overlay as well as the control panel since our fingers went through it. The stove is only 6 yrs old... Anyway, how do you get access to the control panel? We are planning on replacing the component ourselves in order to save $200 in labor. Your help is greatly appreciated!
  • yorkietoo Mar 08, 2009
    Same problem as karen's - the 'more' control button is shot - our finger went through the overlay and the button behind it is completely gone as well so we can only cook at 350-degrees (the start temperature when you turn the oven on) or lower as the 'less' button is still in tact. Our oven is only 7 years old. We too would like to fix this ourselves in order to save on labor.
  • 126 Answers
Here are your part numbers:
Control: 31944801
Overlay: 32061901B
There are several online sources such as repairclinic.com or sears.com just search appliance parts and you can compare prices if you like or you might even call an appliance store to see if they can order them for you. When you decide where to buy use those numbers and you you will get what you need to fix your range. Good luck.
Posted on Jan 07, 2009
The control panel for my Amana oven, model ACS3350AS, turns off mid cycle. How do I know if the panel is fried or it's something else? Is the control panel easy to find and install?
the fitst thing i would do is check the incomig power. make sure you have constant power ad that the range isnt loosing power. if your power is good, then you may have a bad control. go to www.searspartsdirect.com. type in the model and you can view the price for the control
Nov 25, 2011 | Amana ACS3350AS Gas Kitchen Range
I have an Amana ACS3350AS Gas range and the Control panel cover has cracked due to heat.After much searching on the web I found a replacement but I can't seam to find any manuals on how to dismantle it...
hello, this unit should only have screws under the control panel when you open the oven door. some of them have a side screw on each side when you pull out the oven an inch or two. hope this helps
Jun 08, 2011 | Amana ACS3350AS Gas Kitchen Range
Amana ACS3350AS gas range oven door is bent and will not close properly. need to replace oven door and hinges. how much will this cost?
With a hammer, carefully flatten the areas of the door on both sides where it is sprung outward. I then drove self tapping screws into the side panels of the door just above where the bulge formed.
This formed a bond between the outside panel of the door and the inside panel.
Nov 27, 2010 | Amana ACS3350AS Gas Kitchen Range
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
Kenmore dishwasher control panel cracked
unfortunatly youll need to replace the entire control panel, it does not come as a separate mylar overlay,
Mar 17, 2009 | Kenmore Dishwashers
Amana ACS3350AS stove temp in oven stays at 100 degrees . takes 1/2 hour to light or get to set tempeture. replace senor temperature and control panel. what should i do now
We had the same problem and it turned out to be a burned out lower heating element. Only the top one was heating and I could never get it over about 150deg or so.
Mar 16, 2009 | Amana ACS3350AS Gas Kitchen Range
Control Panel has given out (ACS3350AS)
See the solution I posted here:
http://www.fixya.com/support/t519198-amana_acs3350as_never_buy_amana
Jan 02, 2009 | Amana ACS3350AS Gas Kitchen Range
Converting to natural gas
Problem solved! I found the instruction sheet. Thanks anyway.
Aug 19, 2008 | Amana ACS3350AS Gas Kitchen Range
My Amana ACS335AS oven works sporadically.
the amana ACS3350AS control panel is broken, I need to replace it, where can I find it?
Jan 29, 2008 | Amana ACS3350AS Gas Kitchen Range
Amana ACS3350AS Gas Kitchen Range Logo
667 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
