Question about Kodak EASYSHARE G610 Thermal Printer
Ink cartridge won't go in.
I tried to put in a new ink cartridge and had a lot of trouble getting the old one out. When I TRY to put in a new one, the ribbon creases up and won't go in. Is there any way I can fix it?
    President:
  • 8,637 Answers
Normal 0 Double check to make sure you have the right cartridge for the printer. This is a common mistake people are making. It’s easy to do.
Hope this helps. Bud
Posted on Jan 24, 2009
Canon IP3300 won't print color
hi chette,
its a common problem for printer dye ink,have you try to use other cartridge? a brand new one maybe?
if you insist using the old one, try these step.
1. use vinegar to clean your cartridge head
2. put a little vinegar into the cartridge
3. try deep cleaning it.
it only work for dye ink base not else :D
ciaw.
Jul 11, 2012 | Canon PIXMA iP3300 Printer
After changing the black ink cartridge, printer won't work - I have an 6A00 error - no lights are on where the 5 ink cartridges are - help!!
cartridge is not compatible, try putting old one and if work replace the new one.
if still not work then sensor or card is corrupted have to repair/replace them.
please check and post again here.
vote me if found helpfull.
Aug 01, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Missing black ink cartridge
Unplug the printer from the wall. Also remove the power brick for 60 seconds. This will reset any error messages you get from the printer. Plug everything back in and power on the printer. Take out the Dell black cartridge and reseat it. Put it back in and do the same for the color cartridge. When you close the printer it should try to print an alignment page.
Aug 11, 2009 | Dell A960 All-In-One InkJet Printer
Problem with new ink cartridge
More that likely the refilled ink cartridges are faulty and should be replaced. While some folks have pretty good luck with refilled cartridges, it is generally better to stick with the new ones.
As to the problem with old cartridges, keep in mind that the estimated ink levels are just that - estimates. However, if your printer has an option for cleaning the cartridges, try that before chunking them. Take them out, put them back in, and run the cleaning process. Sometimes the nozzles can get clogged up and running the cleaning process will clear them up. ( DO NOT TRY TO CLEAN THE CARTRIDGES MANUALLY!)
If none of this helps, you will more than likely just need to get some new cartridges. - Graye
Oct 29, 2008 | HP PSC 1410 All-In-One InkJet Printer
I replaced my hp ink catridges and the printer is still saying the ink is empty. What do I do?
You haven't mentioned what printer model but you can try th following.
Firstly, try removing your new cartridge and temporarily putting the old one back. Sometimes this will then show as a full cartridge even though it is empty, because the sensor electronics appears to get confused. Next, turn off your printer and turn it back on again, then take the old cartridge out and put the new one back. I cannot guarantee this will work, but it will be worth a try.
Oct 18, 2008 | HP Computers & Internet
Epson R280
Don't try to fix it. Put the machine back in the box and return it Epson for a new one. Do it before the machine is 28 days old or they will give you a graded machine.
The error can be caused by the cartridges themselves but best to get the whole lot exchanged.
Sep 08, 2008 | Epson Stylus Photo R260 InkJet Printer
C60 says full cartridge is dry
You could try taking out the new ink and putting in the old. Then uninstall the program, delete all reference to Epson in Regedit, then reinstall the program.
Change the cartridge when prompted.
Of course, having messed about with the jet, it may not work now !
Jun 05, 2008 | Epson Stylus C60 InkJet Printer
No ink display on brother mfc240c
First make sure that you are using Brother Cartridges, their machines are very sensitive to using generic ink. Put a brand new set of ink in the machine. Pull all the old cartridges out and put all new cartridges in. If this does not resolve the issue contact Brother, they are very good about helping their customers.
Jan 02, 2008 | Brother Multi-Function Center MFC-240C...
Kodak EASYSHARE G610 Thermal Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
