Question about HP LaserJet 4700 Printer
Hp4700 Color laserjet makes groaning noise
No error code but noise on start up and while printing. All color cartridges replaced.
  • ACCES Jan 07, 2009
    Would a new fuser or transfer kit work or will it need to go to be repaired?
  • ACCES Jan 12, 2009
    Problem solved! One bad color cartridge.
    Genius:
  • 2,120 Answers
Could be dry fuser bearings or a noisy transfer belt.
Posted on Jan 07, 2009
  • Leroy Elliott
    Leroy Elliott Jan 07, 2009
    Only replacing them will provide an answer/
Printing laserjet fades from left to right on text only
Anthony try removing the cartridge and gently tilting backandforth a few times. Re-install for good news!
Mar 12, 2014 | HP LaserJet 4650 Color Printer
Replace transfer roller
Groaning noise on this model is usually down to third party consumables, Has this noise started after recently( within 5000 prints) replacing one of the colour toners cartridges, If so - you should replace the same cartridge with a HP OEM product and see if this cures the fault 99%of the time third party consumables do not replace key components when Re-Manufacturing Toner/Drum units to save on cost - however this causes Major issues with the expected Life of the Printer as A whole. Added stress on the drive systems due to poor toner units will invalidate any warranty/Repar Cover you may have, Despite what the adverts say CHEAPER toner Units Do Not Give You Cheaper Prints. They Just amage the rest of the Machine>>>>...
Sep 13, 2013 | HP CP3525DN Color LaserJet Printer
I have two HP Color Laserjet CP3525n printers for my home office. I've owned many HP laser printers and color laser printers (Konica) and none of them have ever made load squeeking noises while...
These are not the quietist printer I have dealt with. Most of the squeeking noises we have encountered in servicing are related to the drums in the cartridges. Are these original cartridges or refills? If original and units are still under warranty, I would go after HP to deal with the noise. If you are using refilled or remanufactured cartridges, some noise is just part of the money saving tradeoff you make.
Jul 26, 2011 | HP CP3525N Color LaserJet Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
Our HP Color LaserJet printer has a 10.10000 error
10.000x Supply error E-label cannot be read or print cartridge is
not properly installed.
10.0001 = Cyan print cartridge
try this:
1 Reinstall print cartridge.
2 Turn on the printer.
3 If the problem is not solved, replace the cartridge.
Nov 03, 2010 | HP Color LaserJet 2600n Printer
My Hp color Laserjet won't print unless all
You have to replace all empty cartridges...no other solution
Oct 19, 2009 | HP Color LaserJet 3500 Printer
HP LaserJet 1500... prints color yellow ONLY
It's possible that the toner in the cartridge is not evenly distributed. You can redistribute toner if you gently shake the cartridge from side to side, then reinstall it to see if this affects performance. Please also see this article.
You might wish to use the guided troubleshooting option available from HP support here. Or have a look at the troubleshooting section in the user manual here. Then clean the engine & calibrate the printer, as described pg. 88.
If that's no help, please see this forum post and the linked attachments within.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 01, 2009 | HP LaserJet 1500L Color Printer
Color Laserjet 2550 Loud Noise when starting up and printing
Remove toner cartirdge and check gears on cart as well as all of the gears you can see inside the unit for any signs of wear. You may also need to remove the fuser assembly and perform the same task with the gears back there. MAKE SURE THE POWER HAS BEEN TURNED OFF AND THE PRINTER UNPLUGGED FOR AT LEAST 30 MINUTES BEFORE ATTEMPTING TO TOUCH THE FUSER. IT WILL BE HOT!!! Most frequently these kinds of noises from the printer are due to gears slipping. Sometimes simply reseating the fuser assembly or toner cartridge will fix it. If there appears to be excessive wear on any of the gears, you will need to replace them.
May 29, 2009 | HP Color LaserJet 2550n printer + HP Color...
Still using color toner when printing in black
Check the black toner cartridge. Most printers that use multiple cartridges will use the black cartridge as long as it has toner in it but will then start using the color toner to do the black/grayscale when the black cartridge is empty.
-Graye-
Nov 21, 2008 | HP LaserJet 2550L Printer
HP LaserJet 4700 Printer Logo
498 people viewed this question
Seeker5211
Seeker5211
