Question about Brother IntelliFAX 2800 Laser Fax
Our brother intellifax 2800 does not have a dial tone and says "sleep" in the display
    Problem Solver:
  • 12 Answers
It is in the "energy star" compliant mode. This setting can be changed to a number of minutes you select in the settings menu. This info should be in the owners/operators manual, or on the CD that usually comes with the machine.
Posted on Jan 06, 2009
I have a brother intellifax 770 that has no dial tone.
hello you neede to clarify the problem so i may help good luck brothetr tech
Jan 21, 2009 | Brother IntelliFAX 2800 Laser Fax
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Nov 18, 2008 | Brother IntelliFax-2820 Laser Fax
The fax machine is in sleep mode
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line . Filter makes no difference.
Nov 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Intellifax 1270 lightning damage. no dial tone
Plug a regular phone into the wall jack to verify that you have a dial tone.
Nov 06, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
2800 will not recieve faxes
Some models will actually stop working whenever a drum message is displayed.
Remember, you do not need a drum to fax out (only to print confirmations) so i would go ahead and change the drum.
Ons ome models you can adjust to how low you want to set it or remove it all together.
It will store it in memory for a while (providing you do not turn off the machine, and print as soon as you replace the toner)
Jul 16, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother lntellifax 2800
If you have a hand set try to use it as a phone. If no dialing tones are present check the phone line connection. If the fax is well connected there is a good chance that you need a part for the machine.
Jun 23, 2008 | Brother IntelliFAX 2800 Laser Fax
Sleeping will not awake
1st check to see if there is a "dial tone"by picking up the handset. Then try to send a fax by using the handset.
Dec 27, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother 2800 fax
Make sure you have the telephone cord plugged into the jack marked "line"
Nov 06, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
111 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
