Question about HP LaserJet 4250n Printer
HP LASERJET 4250n
When I print, there is a smudge. Due to spacing, looks like it's on roller. How do I check this.
This problem is with the fuser. It needs to be replaced. They tend to burn out right in the center leaving a rolling smudge across the page as the unfused toner left on the roller gets printed on the next roll-over.
Posted on May 13, 2009
    Genius:
  • 1,605 Answers
If you print 2 pages and the spacing are equally spaced. then you are right. it is on the roller.
you have to take the ink cartridge out and use water or acohol on a coffee filter to clean them.
Posted on Jan 06, 2009
Identical smudges 3 inch spacing
3 inches is approximately 70 or so mm so i would say you have a bad drum on your toner
27mm - charge roller - Replace toner
75mm - Photosensitive Drum - Replace toner
34mm - Developing Roller - Replace toner
39mm - Transfer roller - clean/replace transfer roller
57mm - Fuser Film - Replace Fuser
56mm - Pressure Roller - Replace Fuser
Oct 06, 2014 | HP LaserJet Pro P1102W Printer
HP LaserJet 4Plus - just changed the fuser and rollers - was getting smudges and shadow on the printer paper. Now getting (on the left 1/4th of the page) light areas with little or no print. The shadow...
Take the toner cartridge out of the printer. Shake it side to side. Reinstall it and print something.
See if that fixes the output.
Could also be the transfer roller.
Jun 28, 2011 | HP LaserJet 4 plus Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
Dell laserjet 1720dn
Reseat the paper in the paper tray, and replace the pickup rollers for both trays, note the pickup rollers are in the trays and under each tray.
Feb 12, 2009 | HP LaserJet 4250n Printer
Printing Problem
GO ON LINE AND TYPE INTHE FOLLOWING INFORMATION; EXAMPLE:
HP LASERJET 4250N PRINTER ERROR MESSAGE KERNEL
ENTER
"" "" "" ILLEGALOPERTORSEQUENCE
ENTER
HP LASERJET 4250N ENDCHAR ERROR
ENTER
HP LASERJET 4250N PRINTER POSITION 24 ERROR
ENTER
HP LASERJET 4250N ERROR MESSAGE [ CODE # ]
ENTER
ROD THE CANDYMANGANDY
Dec 20, 2008 | HP LaserJet 4250n Printer
HP Laserjet smudges across entire page
More than likely you have a bad toner cartridge.
Inkworks
866-381-0541
Nov 03, 2008 | HP DeskJet 5650 InkJet Printer
Poor quality smudge and ink blotting marks in the centre of any printed document
Try performing a test by printing a test page from Tray 1 and open the top cover as soon as the paper is 60% inside. The paper would jam below the toner cartridge before it reaches the fuser. Remove the toner cartridge carefully and verify if the smudges occur. This would eliminate the fuser. If the print quality is fine, then you need to swap the fuser.
Oct 30, 2008 | HP LaserJet 4250n Printer
Smudged printing
Sounds like you are either having a cartridge or fusing assembly issue. Here's how to isolate it. Look at the "tire tracking" and find where the mark repeats itself. Measure the distance between the 1st occurance and the repeat and use the guide below to identify the source.
38mm or 1.5" = cartridge
55mm or 2.17"= cartridge
62mm or 2.44" = Lower Fuser Roller
74mm or 2.91" = Upper Fuser Roller Film
93mm or 3.66"=cartridge
If the spacing is cartridge, simply replace the cartridge. If it is fuser you will need a replacement fuser. Replacement rebuilt fusers are available for about $65.00 plus shipping on exchange from Dale at Seattle Platen, 1-800-221-2388.
Aug 24, 2008 | HP LaserJet 2100 Printer
HP LaserJet 4250n Printer Logo
449 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
