Question about Homelite 'Yard Broom' Leaf Blower
Homelite 26D leaf blower bogs down in Run position
I have a homelite 26D leaf blower that I can crank it up fine but when I put it in the run position it bogs down and shuts off. I put a new spark plug and fuel filter in it and it still bogs down in the run position. What is the problem?
  • 2 more comments
  • mallarddck Feb 27, 2009
    I have a Model UT08131, when you tilt the nozzle down to blow leaves it stops. You must have the gas tank completly full to make it run in this positon.
  • Mark Tripp
    Mark Tripp May 11, 2010
    What is the model and serial number of your blower?
  • Kim Webb Apr 01, 2013
    I have the model UT8542B and it does the same thing'. Please help
  • Bob Trathen Jul 11, 2013
    Ihave Homelite 26D ran Great and went on vacation and now will not start. I have had it for less than a year and have never had any troubles with it. I changed the plug thinking that it may have fouled out. Not the problem. Took the plug out and checked for spark and it started the gas it blew out on fire. Pulled cord with plug out and made sure there was no gas in the cylinder and still will not try to fire. Any suggestions. I do not have the manuel packed it up because I am in the process of moving.
  • 398 Answers
Check the air filter.
Posted on Mar 02, 2009
My Homelite gas leaf blower will crank but will only run for a few seconds. I have changed the spark plug and checked the fuel line but have not been able to fix the problem. What else should I check?
check the "check valve" in the gas cap. open the cap slightly and start the blower. If it runs then it is probably a faulty check valve. Buy a new cap.
Jun 07, 2014 | Homelite Garden
Homelite blower pull cord frozen how do i troubleshoot it
go buy a new blower, you ran the wrong fuell/oil mixture and seized the motor.
May 12, 2014 | Homelite Garden
My homelite blower starts but after on run position shuts down
Ck and see if it has a choke. If it is on full choke, reduse choke after you put in on full run.
Oct 05, 2011 | Homelite 'Yard Broom' Leaf Blower
Bogs down at full thouldel tryed to adjust carberator
Hi
This is either a clogged muffler or carb. Take the off and see if it will rev. If not you need to clean carb and install a carb repair kit. Do not run long with muffler off.
Sam
Jan 06, 2010 | Homelite Consumer Products Backpack...
BX 90 homelite leaf blower two idle screws
The initial setting is 1 1/2 turns out. Screw them all the way in and them turn them 1 1/2 turns out. This is the starting position and should start, it may need some final adjustments to run like you need it to run.
Remember more the screw is out the more fuel it will get.
Good Day.
Oct 14, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite leaf blover run with choke soon when chokeis off ,cant rev up and die
if he put fuel in it dump it out & put yours in it , if problem persist there are 2 screws on the carberator turn the 1 on the right or th bottom 1/4 turn to the left!
Jun 02, 2009 | Homelite 'Yard Broom' Leaf Blower
Oil/gas ratio for a modle UTO8110 homelite leaf blower
I am not positive but we have stihl equip. and some other 2 stoke brands about 35 pieces and we run 32-1 in all of it and have never had any problems that should work for any brand
Jan 27, 2009 | Homelite Consumer Products MightyLite...
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Homelite leaf blower bogs down.
I don't mean to over simplify this, but are you using fresh gas? Gas blowers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with gas blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Sep 29, 2008 | Homelite 'Yard Broom' Leaf Blower
Homelite 'Yard Broom' Leaf Blower Logo
1,494 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
