Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Can't Scan anything on a BizHub C550 to 5 pcs on the same network
I try and scan a paper and send it to 2 computer, but it pops up with an error. saying it can't connect to the network. But its hooked to the network cuz we are able to print stuff off of it from our computer.
Need help. Can't figure out whats wrong.
BizHub C550
  • 1 more comment
  • corey809 Jan 06, 2009
    So how do you connect to the machine on the internet browser?
  • Anonymous Mar 14, 2014
    bizhub c550 error c2a24
    error came up after replacing black toner
Be sure that your Domain name is in the network settings on the printer. This can be done on the printer itself or opening a web browser. Put the IP address in the address bar of the browser, this will conect you to the machine. Log off the public domain that come up and log on the administrator area. Enter the password 1 2 3 4 5 6 7 8, unless it has been changed. There you will be able to set all of the network functions. The machine need this information in order to direct the scans to the correct place.
Posted on Jan 06, 2009
  • administr361 Jan 07, 2009
    If you need further assistance, oyu can call me at 1-508-764-1413. Ask for Jeff.
I would like to teach me to scan the Bizhub C352, ie what are the steps to take to scan a document in BIZHUB C352. thank you Manuel Medina papelariapatrick@hotmail.com
Mack a scan folder on your computer & share it to network the you go on c352 and press scan key - direct input / scan to SMB / reference / work group open / your pc name open / scan folder ok -you are ready to scan any document any help you con- me 919899653281
Mar 19, 2013 | Konica Minolta Bizhub C352 Digital Copier
How can I scan different size paper in one pdf on bizhub c250?
Under original settings for scan select Mixed Originals. This will allow you to scan 8 1/2 x 11 and 8 1/2 x 14 at the same time.
May 05, 2010 | Konica Minolta bizhub C250 All-In-One...
Have a bizhub C353 conected to a network. Using a
have a bizhub 250 trying to scan to pc via smb on a network. Keep getting login failure. Can you help
Nov 12, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
MACHINE REFUSES TO SCAN SHOWING ERROR EA3229 ON BIZHUB 200 COPIER
As with most communications errors the first thing to always try first is shutting off the copier, unplugging it from the power source for at least 30 seconds, then plugging it back in, powering up and trying the scan-to-email functions again (once network synchronization has been completed by the copier).
EAXXXX is a communication's failure code generated by the copier to state that 1. The LAN cable is not physically connected, 2. Communication with the SMTP server has been lost, or 3. One or more of the e-mail addresses that someone attempted to send mail to doesn't exist or is invalid.
If the scan-to-email functions worked before this and have suddenly stopped, you may want to have your IT department reset the mail server.
It's also possible to have had some changes made to internal network address that has affected the copier's ability to communicate with the servers. Check with your IT to see if they've added any security software, changed network address structures, etc., around the time that the scan functions failed.
Aug 28, 2009 | Konica Minolta bizhub 200 Printer
Im trying to scan and the canon says: "set the pc to start scan"...? Nothing pops up on the computer, what do i need to do?
I'm using an MG5220 and got this same message. Here's how I fixed it.
On the printer control panel press the soft key to select the scan function. Then hit the soft key to select Save/Forward. Then select Foward scanned data to a PC. On the next screen make sure to select the appropriate PC. In my case I'm connected wireless but the selection was set to USB connection and that's why I was getting the error noted above. When I picked the PC that is connected wirelessly everything worked fine again.
Jul 12, 2009 | Canon PIXMA MX850 Multifunction Printer
Hi, I just took over a BizHub 350. Whenever I try to scan to a new email address, it doesn't go through and I get the error message "EA3226". Whenever I try to scan and email to an existing email...
The scan-to-email may have been set up originally to utilize the old email server, using the old domain as the conduit for sending the scans through your network.
You may have to load the driver onto the new email server, or the main network server itself (which would then allow you to scan to emails with any destination as it is using the networks connectivity to deliver the emails, not the email server).
Then you can set up as many new user accounts as you want.
Jun 25, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
We have a KM c250 that we use for scan to desktop and occasional faxing. Starting last night we started getting an error when scanning. In the log is says that it is a Forward TX Error. To my knowledge...
hello this can be caused if the scan sends to a wrong IP adress. If the machine that you are sending scans has dynamic IP (dhcp), then the ip can change as you reboot the computer. To solve this, have a fix IP adress in your computer's network preferences, and check if scan sends to this adress
May 29, 2009 | Konica Minolta bizhub C250 All-In-One...
Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Feb 20, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 250 scan to email error
Try re-entering user name and password or try a different user name and password for email account saved in the machine.
Jan 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
547 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
