Question about Toshiba Estudio 200L Copier
I need part number for estudio 200 fuser and image unit
I need these parts to fix customer problem
  • Anonymous Apr 01, 2009
    I need part number for e-studio 200 fuser unit.
    My e-mail address is wonderfulc@burcomw.com
    Please help.
    President:
  • Toshiba Master
  • 990 Answers
Hello sir; we do carry those parts if you need that please email me your phone number,
Posted on Jan 06, 2009
Call for service C413 toshiba estudio 2006
Here is the verbage for the error code at this link
http://printcopy.info/?l=en&mod=erc&brand=Toshiba&model=e-Studio%202006&code=C413
In the interim you may try the following one time to see if it is a false error... Hold "0" and "8" while turning on machine.....continue holding until machine enters service mode. Enter "400" press enter. Enter "0" press enter. Power off / on. If code returns, machine needs parts replaced. Contact your Toshiba technician (there should be an 800 number label on the unit for service. Do Not keep resetting, may cause damage to Fuser Unit.
Aug 11, 2016 | Toshiba Office Equipment & Supplies
Erro code e02 in toshiba estudio 181
hello
dear you have to verify all the exit sensor related
1. do u have look on fuser unit drive gears.
2. is the exit rollers are good some time exit roller got damaged they don't hold hold paper to run out from machine.
3. do u have clean the exit sensor.
4. do you have verify that the exit sensor actuator is free to operate the sensor.
5. some time exit sensor actuator broken.
Aug 28, 2014 | Office Equipment & Supplies
How to ikj adjust estudio 350How to ikj adjust estudio 350How to ikj adjust estudio 350How to ikj adjust estudio 350How to ikj adjust estudio 350How to ikj adjust estudio 350How to ikj adjust estudio 350
If wait warming is occur on the panel, and it wouldn't change to ready, then fuser unit is the cause. Need to check the themistor and themostat on fuser unit.
Feb 15, 2014 | Toshiba e-Studio 350 Copier
I have bizhub c250 and the 83000 prints (copies). My Fuser unit show empty and I can't use my bizhub c250. it should be replaced on 120 000 copies. How to reset this fuser unit on my printer?
You can reset the fuser counter only by replacing the counter reset fuse. This fuse is located on the fusing unit which must be removed and a small cover opened to get access to the fuse. You ca get the fuses from precisionroller.com
Their part number is M9970. It will say imaging unit fuse but the fuse is the same for the C250 fuser reset.
If you do not feel that you can remove the fusing unit and replace the fuse then you might be able to find a local independant copier repair person to do it.
Be assured tho that you can reset this indicator as I have done this a dozen times or more for my customers.
Good Luck and Thank You for using Fixya.
Nov 04, 2010 | Office Equipment & Supplies
Help! My printer is printing text and then leaving like a shadow or very light imprint of that text on other pages. Too, there are a few ink splotches here and there on the various pages. Does the printer...
First, if you have one available swap out the toner cartridge. It is possible on this series for the toner cartridge to cause double imaging. This is especially true if the double imaging is across the entire page. If the double imaging is in more of a streak or line down the page especially on one edge then is it more likely to be a fuser film going bad. You can replace the fusing unit yourself if you want. Just do a google search for HP 4350 fuser unit (going by the picture in your post)
About $150 to $200
If you can find a guy, you can have just the fuser film replaced in your fuser unit at a cost of around $175 for parts and labor.
The most expensive route is to have a service company replace the fuser. They will charge you around $300 parts and labor.
Jul 07, 2010 | HP LaserJet 4250n Printer
When I print something it lifts a line of the ink and prints in further down on the paper so there is a lighter image of that line further down.
This is coming from the fuser unit. You have 2 options. My preference and the option I provide to most of my customers is to just replace the fusing film in your existing unit. You can have this done for around $150
You could have the whole fusing unit replaced with parts and labor running you about $300
Or you could replace the unit yourself if you are mechanically inclined. You can find fusing units at many places on the web at around $200 and should come with replacement instructions.
Either way the problem you describe is a classic fuser film defect on many HP models.
Jun 08, 2010 | HP LaserJet P3005n Printer
The printed image is partially removed as if it is sticking to something in the printer? nIs this the fuser unit?
Hi.
If the toner is loose, and not well fixed to the image , that is usually because of a faulty fuser unit.
The fuser is the lamp that is supposed to heat toner, if the fuser is not releasing enough heath, then the toner dust will not be properly fixed to the paper, and you get this problem.
If instead you do not have trace of toner dust, but you have dropouts, and part of the print is missing, then it may be a fault concerning the high voltage unit that powers the Drum.
In both situations service is due, and you should call the service number listed on the owners manual to get a quote on repair.
Before calling service you can try replacing toner and cleaning the printer inside , even if I do not think this will make any difference.
Regards.
Nov 14, 2009 | Ricoh CL4000DN Laser Printer
Toshiba estudio 350 the error code is wait warming how can i fix this
Dec 29, 2008 | Toshiba e-Studio 350 Copier
141 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
