Question about Samsung Televison & Video
Configuring a Samsung HDTV with a HZT 310 Home Theater System
What is the best way to connect a Home Theater system to an HDTV? Inputs to outputs etc. to optimize the best audio and video. I followed the diagram in the manual, however, I the audio is not what I expected. Perhaps I'm missing a connection somewhere.
  • 3 Answers
SOURCE: home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Posted on Jan 19, 2008
SOURCE: variable audio out has no output
I turned off the internal speakers in the TV and the external speakers then worked.
Posted on Feb 26, 2008
SOURCE: No Audio Out through the Optical OUT jack
just press the DVD button on the remote contol and you will be ok.. :)
Posted on Aug 31, 2008
DickCanFixIt
  • 948 Answers
SOURCE: Having problems with HDMI connection
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Posted on Jan 01, 2009
DickCanFixIt
  • 948 Answers
SOURCE: How to Hook up HDMI from Comcast Motarola Cable Box
Is JVC-DVD digital cinema home theater system supports Audio return channel
Best way is to provide more information like TV model #, home theater model#
Mar 07, 2018 | Audio Players & Recorders
Can i connect dmp-bd871 to a home theater system
It will depend on your home theater system and TV. If your system accepts HDMI in from other devices and HDMI out to the TV, connect an HDMI cable from the blue-ray player to an HDMI input on home theater system. Then connect another HDMI cable between the home theater system and the TV. This will provide the best video and audio experience.
Another option is connect the HDMI cable from the Blue-ray player to the TV. Connect the audio output of the TV to the home theater system. (This will depend on the TV as well as the home theater system. Some TVs have digital audio outputs; others have analog outputs. If your home theater system doesn't have the same input as the TV's output, you would need a converter as well as the digital and analog audio cables. This is an example of one for digital to analog: http://www.gefen.com/kvm/dproduct.jsp?prod_id=4907 .)
If you do not want to get the best picture from the Blue-ray player and your home theater system has analog audio inputs, you can connect the composite video out to the TV. Then connect the audio outputs from the player to your home theater system. (This means only an SD picture will be provided to your TV.)
Panasonic has the manual for the DMP-BD871 here: service.us.panasonic.com/OPERMANPDF/DMPBD871-MUL.PDF .
I hope this helps. Please add a comment with the other devices in your entertainment system or their inputs/outputs. Then I can add specific information for your system and any tips for setting up the system.
Nov 26, 2012 | Panasonic DMP-BD871 Blu-ray Player with...
CONNECTIONS AND SETUP
Setting up the home system to the TV means you have the option of the sound deing routed to the audio system. Now it depends on the availability of the inputs to your home system which is not mentioned and if this is basic you can connect the audio outputs L&R to the repective inputs in the home system.
If HDMI/coaxial is available then you can do so. The home system speakers must be connected one by one accordingly with the correct polarity and tested by choosing the input.
Dec 20, 2011 | LG 42LC2D 42 in. LCD HDTV
I'm Tryin to connect a samsung blu-ray (BD-P1500) to a samsung home entertainment system (HT-D555W) with a samsung LCD tv (LA 40C650L1F) need the best way to connect them .... Thanks
Find the manuals and refer to them.
My personal spin on the instructions:
NO signal ever benefits from multiple connections or 'hops' and it gets expensive zig-zagging a signal all over the room. K-I-S-S is the word of the day. Run the BEST version of any signal directly from its source to the BEST electronics that will present it to you for consumption. The separation of audio and video inputs and outputs on a device is what allows and ENCOURAGES the direction of each signal to the BEST electronics that can process it. Example: your TV does not have the best speakers in the room so why send it any high-end audio?
Aug 21, 2011 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
How do you connect the speakers on to your flat tv. I read it on the manual that u have to use HDMI, but i did. It still won't work.
This model has speakers. If you are trying to connect external speakers i.e. a home theater system, receiver or a sound bar you have a couple options.
This television only has hdmi inputs so you cannot connect the external speakers with hdmi cables. The television would have to have and hdmi output.
Now in order to use hdmi you would have to connect all your devices to the home theater and then go hdmi out from the home theater to one of the two hdmi inputs on this television. Then you would leave the television on that hdmi input at all times and switch devices with the home theater remote.
All the devices would be connected from their respective outputs to a respective input on the home theater.
Another option is to connect a fiber optic cable from the television to the home theater.
Another option would allow for stereo sound but not the higher quality surround sound. You can connect from your televisions red and white RCA outputs to the RCA input on the home theater.
Dec 30, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Hdmi input from does not receive signal. Have connected output from cable box directly to TV and signal is there. Unit does not pick up signal. HDMI output from component works fine, as I can play DVDs and...
I have the same issue. I've opened up several tickets with Samsung tech support. I'm concluding that it's the BluRay rcvr has bad hdmi input & output circuitry. I'm returning mine to Best Buy where I purchased it for a replacement. Before I leave the store, I'm going to make sure that the replacement unit's hdmi inputs & outputs work @ the store.
Dec 28, 2010 | Samsung HTTZ522T Theater System
How to play music on pc on home theater system
hello. i was just looking over the panasonic manual for your system and it doesnt look like there is any extra inputs to hook anything up. i think from what i was looking at the home theatre system has fm radio on it right? what i do sometimes is use a wireless fm transmitter that i have and plug that into my laptop and set the radio to the station the transmitter is set to. it works ok. you can get them at radio shack and best buy and places like that. let me know if that helps
Apr 21, 2009 | Dell Inspiron 1525 Notebook
Having problems with HDMI connection from COMCAST Motarola HD Dual TUNER DVR HDMI DCH6416 to Panosonic Home Theater system SA-PT660 to AKAI LCD HDTV. There is only one HDMI Output on the COMCAST box; one...
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Jun 16, 2008 | LG LHT734 System
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Televison & Video Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
