Question about Brother MFC-8460N All-In-One Printer
Weird noises every time we go to print the printer makes a weird noise like grunting like a pig and we can't find any paper jam.
    Champion:
  • 320 Answers
You may not have any paper jammed in the machine you may be lubricate the gears if you are handy good luck
Posted on Jan 26, 2009
My polariod pogo, seems to be jammed but their is no paper inside and when there is it doesn't want to print and says check printer and it makes a weird noise. HELP!!
A weird noise suggests either the mechanism is broken or there really is a jam.
When there's no paper inside, how sure can you be that there isn't even a tiny piece of paper, smaller than your smallest fingernail, in any part of the mechanism? One way to remove a tiny scrap would be flush it with a vacuum cleaner set to blow...
May 19, 2016 | Office Equipment & Supplies
HP Photosmart C6280 All-in-One making weird noises
this is hope, i had this problem once. what it was was a small piece of paper that was caught in the rollers. i know you said this, but check again, I am almost positive this is your problem
lastly, check the black cartridge, take it out make sure nothing is stuck to the ink dispensary for clear printing
hope this helps and good luck
Apr 29, 2010 | Office Equipment & Supplies
X5470 lexmark has paper jam now makes squealing noise when I use it!
Try this. Remove any paper jams, take out all sheets of paper and remove all cartridges from the printer. Close the cover. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer's ready, re-insert the cartridges. The printer will print an alignment page. Load just 5 sheets of paper only. Let it print the alignment page all the way through without cancelling it. If printer is not making the squealing noise, problem resolved. If it's still making the noise, the printer's mechanism somehow got affected by the paper jam now. If that's the case, any mechanical/hardware problem in the printer, it's better to ask assistance from Lexmark. If printer is damaged already, and it's still within warranty, they might send you one for replacement. Good luck!
Apr 07, 2010 | Lexmark X6170 All-In-One InkJet Printer
Problem with Deskjet 895cxi
You may open the rear door to check for any paper jam in side
or if it still gives error rotate the roller in upward direction till you get one locking sound, restart printer and check printing
if you still find grinding noise from printer, its pickup roller gear may be worn-out generally and need to be replaced
contact service person for further repair
Nov 08, 2009 | HP DeskJet 895cxi InkJet Printer
Weird noise from printer carriage
The loud clicking noise is probably the carriage trying to move and something is keeping it from doing so. Check to see there are no foriegn objects obstructing the carriage head from moving across the paper. If nothing is found, then likely a hardware error exists.
hope this helps!
Aug 31, 2009 | HP Photosmart 3180 All-In-One Printer
ADF Jam
It sounds like the grabbing wheels in the document feeder are losing their grip. You can take alcohol to rub down and clean the rubber tires in the document feeder. There is a possibility that a very small piece of paper is jammed in the feeder as well, which can cause the paper to jam and make a weird noise. Please let me know if this resolves your issue. Thank you.
Mar 27, 2009 | Dell Photo 964 All-In-One InkJet Printer
Constant yellow blinking light, no paper jam
I found this on the HP support site:
The power light is on, and the resume light is blinking.
c00109831.gifc01272271.gifc00109834.gif The printer might be waiting to complete a print job or to receive data from your computer.
Solution
Wait for the printer to finish the current task. The printer is waiting for the ink to dry on freshly printed paper.
Solution
  1. Remove the paper with fresh ink.
  2. Press the resume button.
The printer might be out of paper.
Solution
  1. Load paper in the paper tray.
The printer might have a paper jam.
Solution
Clear the paper jam. If the resume light continues to blink after the paper jam is cleared,
OR
if the print carriage is stuck or making a grinding noise, then follow these steps.
Solution
  1. Lift the top cover of the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts. Unplug the power cable from the wall outlet.
  4. Movethe print carriage toward the middle of the printer (this proceduremight take a couple of tries to get the timing correct).
  5. Remove the print cartridges and close the top cover.
  6. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover.
The printer may be ready to eject banner paper.
Solution
Press the resume button to eject the banner paper.
Mar 14, 2009 | HP DeskJet 5550 InkJet Printer
My pinter says paper jam I have have taken the back portion off and then looked thru the paper window with door open as best I can as best the wheels turn but when it start s to print I cam hear it...
The noise of the printer is not related with the software of your computer. If it says out of paper then you will try to clean the rollers of the printer. If it is still saying out of paper and have a weird noise then the printer is already defective.
Aug 14, 2008 | HP Office Equipment & Supplies
Brother MFC-8460N All-In-One Printer Logo
309 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
