Question about Mitsubishi VS-50605 50" Rear Projection Television
Vs-50605 Mitsubishi The television still work but the remotes stoped working. The fuctions on the front of the television will still control the menus but again all of the remotes will not change channels, inputs, volume or power on/off. Any help? Thanks Eric
    Genius:
  • 1,694 Answers
Infrared pcb is located inside mirror cavity mounted to CRT support frame.Follow lead to signal PCB--is it plugged in,to the correct location??----Then suspect bad infrared detector PCB.Or,possible bad signal PCB.
Posted on Sep 28, 2007
Mitsubishi VS-50605 - no vertical control until it warms up and it is now starting to flash to a black screen
Howdy,
CHECK AND REPLCE C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR) BOTH ARE ON THE SIGNAL PCB.
Good Luck, big IRISH.
Dec 29, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Tv wont turm on
If TV will not come on when you press power on front ,then you have something wrong with TV.If Remote is problem you can go to dollar store and buy another one with code book to program TV with for 5.00. you may need to replace your STK ICs?
Jan 10, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 50605
Got the info. Working on my second 16 hour day. I'll update this tonite. Sorry about the delay.
Dan
Oct 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Repair help
Good Day, limao247;
Your TV may fluid on the PCB's. Remove the speaker grill, the small panel and look closely for fluid on the boards towards the front. Always unplug the TV for your SAFETY. If you find fluid clean board with acetone. Good Luck, big IRISH.
Aug 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Tv problem
Check the connections on your front control panel PCB to see if they are all secure then trace them back to where the plug into the chassis and check the connection there as well
Mar 01, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi Vs-50605 TV dead
First thing on a Dead VZ7 to check is the solder connection at the yokes "DY" Connector. Then Check C411 2200uf @ 35V
Then C412 10uf @50V. Then Check IC700 Pin 20 for 0VDC any voltage other than 0VDC on that pin means Diode D980 is leaky.
Hope this helps. If you need anything further let me know.
Jan 15, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
VS-50605 Screen
might measure the opening and buy a piece of plexiglass, wont look quite as good, but cheaper than a new one and usually available at glass shop.
Jul 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
