Question about Zebra Z4Mplus Label Printer
Printer not calibrating correctly
I have a Zebra Z4Mplus. When I calibrate for either thermal or direct thermal labels, it goes an extra quarter of an inch beyond the end of the label. I've tried manually fixing it, but the problem continues when I print.
Reset it to factory default.
Posted on May 21, 2009
    Problem Solver:
  • 9 Answers
Sound like the tear off is set incorrectly, or printer is set to rewind mode.
Posted on Jan 27, 2009
Prints label then prints a blank
This is always a calibration or label template size issue.
Feb 04, 2013 | Zebra Eltron LP 2824 Thermal Printer
Hi WITH THE ZEBRA DESIGNER I SETUP MY S4M FOR A 4X 6 INCH LONG LABEL THERMAL DIRECT BUT PRINTING STARTS ON THE MIDDLE OF THE LABEL AND GOES OVER THE NEXT LABEL TRIED TO CALIBRATE VIA SOFTWARE BUT WAS...
This will make your printer feed out 2-3 labels each time it is turned on or the head is closed to determine the label length.
SET/UP EXIT
Hit the "+" quite a few times until you get to "MEDIA POWERUP"
Hit SELECT
Use the +/- keys to enter the password (1234)
Hit SELECT - you should see a small - and + button on the screen on either side of NO MOTION (if not, repeat previous steps)
Hit the + sign until you get to CALIBRATION
Hit SELECT to exit MEDIA POWERUP
Hit the + button to go to the next item HEAD CLOSE
Hit SET/UP EXIT (twice) to save changes (permanently)
Open and close the printhead to check to see if it worked!!!
Jun 08, 2011 | Zebra S4M Thermal Label Printer
I have Zebra LP 2844-Z printer and the barcodes
Here are 3 suggestions.
Check that your label size definition is correct, measure your label height in mm and check that your printer driver settings match.
Perform a calibration. How?? when printer is on labels loaded and green light, hold feed key and wait for 2 blinks then release feed key. (If you release it after 1 flash you will print a configuration label)
If you are using Zebra Designer, download latest version of Zdesigner V2. Install latest printer driver V2.63. This driver & Zdesigner allows you to calibrate the printer directly from within Zdesigner. Go to File/Printer settings/ advanced options and click calibrate at bottom of page. when printer calibrates then tick the box USE PRINTER SETTINGS and printer will now work properly.
Jul 01, 2010 | Zebra LP 2844-Z Thermal Label Printer
ZEBRA z4MPLUS LABEL PRINTER
Do Media and Ribbon Calibration . in printer parameters
Jun 29, 2010 | Zebra Z4Mplus Label Printer
Why is my Zebra printer printing every other label?
The labels you are printing have an extra line feed (a blank line) after the last printed line. Remove them.
Remove any "FormFeed" from the label run, if you are doing a "merge".
Line 1 Name
Line 2 Address
Line 3 Address2
Line 4 City St Zip
Line 5 <Blank>
Line 6 <Blank>
Sep 21, 2009 | Zebra LP 2844 Thermal Printer
Zebra Z4Mplus won't calibrate 2" Circle Labels
try to set the printer to the factory default setting
Aug 13, 2009 | Zebra Z4M Printer
During manual calibration of the Z4Mplus the
Let the printer calibrates itself or have a manual calibration in the printer setup. You can also press the keys FEED, PAUSE and CANCEL, turn on the printer and release the keys when feeding the labels.
Roberto Martinez
Jul 07, 2009 | Zebra Z4Mplus Label Printer
Zebra z4mplus
iN THE DRIVER CHECK THE head TEMPERATURE ISSUE. Most certainly you do not heat enough to do the transfer.
Else your ribbon is not mounted correctly. Zebra has an out inking transfer film
May 21, 2008 | Zebra Z4Mplus Label Printer
Manual calibration of labels not working, printer not feeding labels correctly
printer manufacturers has different standards depending from the varieties of model and brand of printers for example an epson printer model who is older version is not the same speed print with the recent model likewise with the other brand. Therefore calibration of labels is depending to the version of the printer you are using now.
Apr 22, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
754 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
