Question about Hotpoint 23 in. BFI68 Built-in Dishwasher
Function buttons do not work on off button does
Hotpoint dishwasher bfi 680
I have expreienced the same problem and carried out a hard re-set by holding down the on/off switch whilst pressing the program button. It's now working - but not sure for how long!
Posted on Feb 28, 2009
HOTPOINT DISHWASHER BFI 620 ERROR CODE LED FLASHING 1 & 3
Check the end of your drain hose for the clog.
Feb 17, 2013 | Dishwashers
My dishwasher model No. is Hotpoint BFI680, There was water lying in the bottom after a wash and it couldn't be restarted, I cleaned it out and took out the drain pump and connected it up to 240volt and...
Hello!
As the manual says:
If water remains inside the
dishwasher, check:
the drain hose is not kinked.
the drain syphon is not
obstructed.
the dishwasher filters are not
clogged.
i also add a link to this manual, hope it will help
Hotpoint BFI 680 User Manual Page 13 of 20
May 23, 2017 | Dishwashers
Just moved house dont know how to operate hot point dishwasher model no-bf 168
The manual for the Hotpoint BF168 dishwasher is available here: http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Dishwashers/BFI68.pdf . If the direct link doesn't work, start here: http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do . Then enter Hotpoint and Dishwasher in the Browse for product drop down menus. Then scroll through th pages to find your model.
Make sure the water is on, then load the racks. Fill the dispenser with the appropriate amount of dishwasher detergent. Press the On/off button on the right of the washer control panel. Press the wash program selector (the leftmost button) until the desired program type (icons to the left of the button) has the LED light up. Then close the door. See the manual for delayed cycles and adding salt for the water softener.
I hope this helps.
Mar 14, 2011 | Dishwashers
Hi My BFI 680 trips the electricity at the mains just as you put it on. Have cleaned the filters. Any ideas ?
could a internal fault in m/c[shorted wires] water,faulty on /of switch,recheck wiring to m/c
Dec 31, 2009 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Hotpoint bf1620 dishwasher flashing light fault
Hi ,When this happens I keep the button with the letter "P" Pressed until the fault lifgt resets,my row of buttons is inside the top edge of the unit.
Sep 01, 2008 | Hotpoint 23 in. BF50 Built-in Dishwasher
Dishwasher does not heat up
the heater t.o.c will be blown it may be resetable access by removing the side panel if the stat is resetable it will have a red button on the top simply press till you hear a click good luck
Jul 21, 2007 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Selecting cycle and starting
I'm assuming the programs are all selected electronically...then your pc board is on its way out. In this case you would have to replace the board...most electronic boards have "service programs" which you can check functions, but I'm not familiar with Hotpoint.... Oshie
Jun 22, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Please help
(WASH & DRYING) lights mean the temp is not high enough - aka means the heating element has gone requires a new one at a cost of £40 for the part and £90 hotpoint call out charge same has gone wrong with mine!! to avoid this cost get covered with http://www.domgen.com (uk only) as far as i know check it out!!!
Nov 06, 2006 | Hotpoint 24 in. FDW60 Free-standing...
Open Questions:
See all Hotpoint 23 in. BFI68 Built-in Dishwasher Questions
Hotpoint 23 in. BFI68 Built-in Dishwasher Logo
392 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
