WESTPOINT COLOR TV MODEL TY21-TN
hi,
i have a problem regarding my WESTPOINT brand colored tv
w/ model TY21-TN. pls give me information regarding Q606-W08409.
thanks,
joemari
philippines west point
  • javier_sanch Jan 13, 2009
    I can't find any universal remote control that workds for my West Point TV. Can anyone help me?
  • Kapil Gunasekera Apr 24, 2014
    Q606 - 13007 transistor....+b swich...
3 Suggested Answers
informatica
  • 1114 Answers
SOURCE: A410 (PC1156)user manual needed
You can download the manual from the link below: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=221&modelid=11930 Good Luck!
Posted on Aug 11, 2007
  • 13 Answers
SOURCE: need tv code for phillips model # pl5120 c121 for rcr311w i cant adjust color
There are a few codes you can try for the Philips TVs:
1002, 1003, 1004, 1008, 1012, 1019, 1062, 1068, 1069, 1075, 1076, 1087, 1219, 1238
To look up these and codes for other TVs, go here:
http://remotefinder.rca.com/default.aspx?site=rca
The manual for the remote can be found here (as of 06/07/2009):
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Posted on Jun 07, 2009
Tv seems to only have red and green colors
SOLUTION: Set "Option Data" and "Model ID Data" after replacement of the Main TN / AV Signal
PCB for then model being serviced. Refer to Service Instruction INST2007-040 Rev 1 after
replacement of the Main TN / AV Signal PCB
Dec 28, 2010 | Toshiba 42HL67 42 in. LCD Television
LOST COLOUR: C29 F500DR The colour seems to have disappeared on my Wow by srs C29 F500 DR. I have a digital set top box attached. I cannot seem to restore colour. Any adjustment of the picture via remote...
I suspect that you have connected via componet I would check the red green and blue cables
you may have lost a one of the colors but check the cables first
is it b/w on it's menus?
if it is you have a color element out
Sep 22, 2008 | Hitachi Televison & Video
I have no picture or sound when iturn t.v.on iunplugedand let set about 10 minutes and have same problem
Most current designs of TVs would need a couple of hours unplugged before it would reset itself to default settings. There are some instances that overnight would be better.
If this proves to be not corrective, please post back with the brand and model of your TV.
Hope this be of initial help/idea. Pls post back how things turned up, details as requested or should you need additional information. It would also be of help if you can post any indicators such as blinking lights (LEDs) colors, their blinking sequence and anything else out of the ordinary.
Good luck and kind regards.
Feb 01, 2008 | Televison & Video
The indicator light "lamp replace". Lamp replaced and the screen color is still pink. Help!
The lamp only affects brightness. If the color is not correct the lamp will not fix this. Check cables if using the color stream input. If color is off on all inputs and even the tv menu then replace the light engine. If you could list the brand and model I could give you some more helpful information.
Nov 15, 2009 | Televison & Video
Humming noise coming from TV and picture color fluctuating
Humming is very common on this brand and model of tv. It is usually the cooling fan and the color wheel, the color wheel is the one that get loud. I think that is our culprit. I will get back to you with more information shortly.
Sep 14, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Lost green color in picture
I would start by obtaining the service manual. It will have circuit diagrams and diagnostic procedures.
Nov 04, 2007 | Jensen TS2050J 20" TV
I am French and live in US I bought here a TV SAMSUNG Series 6 - 650- I also bought a DVD player able to read any DVD but for DVD zone 2, it's in black and white What may I have to do on TV to read DVD...
Offhand in all probability and since the Samsung was bought in the US, it uses the NTSC color system. Even if the player is capable of multi regions including PAL/SECAM (Europe/region 2), the TV is not capable of displaying the other color system. Sorry, a multi system TV is also required.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | Samsung Televison & Video
Humming from HLP5063WX TV and no color
Initially, it would be suggested to try viewing a DVD or a VCR and determine if the humming sound & no color persists. If yes then conclusively, there is something wrong with the TV. If none, then the source of the humming sound would be the tuner section (internal to the TV) or your cable TV/aerial or your cable box/decoder.
If the humming sound and no color is present in either TV tuner/channel and with an external video source such as a DVD, then chances are that a large filter capacitor inside the TV needs to be replaced. It would probably be in the power supply section AC side.
If the humming sound and no color is present only on TV tuner/channel, you would have to check your TV signal source. If you are using an aerial, it may require re-orientation; if it were a basic cable, then you would need to consult with your cable provider; if you are using a cable box/decoder, then the problem could either be with the box/decoder or again your cable provider.
May 04, 2008 | Televison & Video
I need to know what kind of ink to use for my lexmark z32 printer and the model number
For a Lexmark Z32, the different inks are:
#60 - color cartridge (17G0060)
#50 - black (17G0050)
#90 - photo color (12A1990)
#65 - high yield color (16G0065)
#55 - high yield black (16G0055)
Hope this be of help. Pls post back how things turned up or should you need additional information.
Jan 29, 2008 | Computers & Internet
Startech USB 2.0 TV Tuner
Pls verify that the tuners color standard is identical to that of the video camera. Depending on where you are, there are a number of color system but dominant are PAL (for most European) and NTSC (for US). So you have to select which ever is being used by the video cam.
Hope this be of help.idea. Pls post back how things turned up or should you need further information.
good luck and kind regards.
Jan 25, 2008 | ATI TV Wonder 650 (DNH100715331) Video...
Televison & Video Logo
446 people viewed this question
Top Televison & Video Experts
Electro Med Services...
