Question about 1995-1997 Chevy Suburban Ignition Starter Alarm switch
Fuel system not working
All fuses and relays seem to be good. changed pump still no power. any ideas?
  • hello, have you checked the fuel pump relay?
  • It´s located in the fuse box in the engine compartment.
Posted on Feb 09, 2009
92 tercel wont start.
Make sure the white wire to the pump has a good ground connection to the chassis. Then trace the power through the circuit opening relay. This is the most likely problem, as this is a dual relay. The relay coil gets battery positive from the starter relay, which you know is working or the starter would not turn. Check to make sure the white wire has a good ground connection. see diagram below.
Nov 09, 2017 | 1992 Toyota Tercel
1989 pickup no power at ecu fuse no fuel gauge
start at pump with key on test for power then move to under dash or where you fuse block is test for power at the fuel pump fuse or it may fall under a different fues there is a sercut for the pump relay like on a jeep wrangler if fuel pump wont work it is the dome light fuese that completes the sercut for fuel pump relay (yes i said dome light fuse for fuel pump relay its true) as funny as it seems that is true so perhaps yor yota is same also somtimes a fuse will test good but is coroted or rusty try changing a couple of fuses that may seem corted or rusty or dirty looking beleve me it is somtimes the dumest things that are the hardest to figure out also try switching a relay with another to try it or try fallowing the wires could be bad or coroted ground as well do you do alot of off roading with it
Mar 01, 2012 | Cars & Trucks
I have a 06 f150 5.4L the fuel sending unit went out so i had to change to pump and everything, the pickup ran fine before but wen i put the new pump in it will not work so i tried resetting the fuel pump...
Hello, There is a fuel pump Relay in the Powerbox under the hood. The system works this way. When you turn on the Ignition switch, it trips the Fuel pump Relay. The power is routed to the fuse from the Relay and then to the Inertia (safety) cutoff switch. Finally the power reaches the Fuel pump.
You need to test the fuse holder for power before it flows through the fuse. You should have the Ignition on, in order for the Fuel pump Relay to provide power to the fuse. Although the fuse may be good, it can not work without power.
On most Models, the horn Relay is the same part as the Relay on the Fuel pump. Just check your part numbers and swap out the two parts and see if it helps.
Jun 24, 2011 | 2006 Ford F-150
I was deppressurizing the fuel system in a galant 2003 2.4L 4 cylinder engine. pulled the fuel pump relay then put it back in correctly Car wont start. both relays r good fuel pump does Not turn on at all...
disconnect the battery, this should reset the computer.Make sure that you have the radio code for the anti-theft and know how to reprogram it(enter the code0 Good Luck Tim
Apr 18, 2011 | 2003 Mitsubishi Galant
No power to fuel pump
Try looking at the fuse under the hood make sure your getting 12 volts at fuse.If fuse is good but no power try checking the fuel pump relay. you can switch the relay with another system that you know works. Lastly Check you Auto Shutdown Relay (ASD). If there has been an accident this relay will kill your fuel pump power. good luck.
Apr 11, 2010 | 1998 Ford Explorer
1988 subaru gl 1.8..no power to fuel pump, fuses and links are good. pump works fine with power probe, just not getting power to it..diagram shows black and yellow wire to pump. it is in fact a blue...
The blue wire changes to Blue/White. It gets power from the Fuel Pump Relay. Fuse number 11 is the power source. The relay is up under the dash panel, blue connector
Nov 04, 2009 | 1988 Subaru GL-10
1994 buick park avenue . driving home and shut off
how did you jump the fuel pump relay, by bypassing the relay or by applying power to contact that closes the relay? If you bypassed the relay completely you need to b ench test the relay you can do this easily by using any 12v dc power source. If you tested the fuel pump relay by applying power to the relay and the pump run and developed pressure. I suspect a wiring or ground issue. Good luck
Oct 07, 2009 | 1997 Buick Park Avenue
2000 jeep wrangler just shut off changed fuel pump
check foe fuel pump presure at fuel rail,,,if u have fuel pump presure check all fuses with a test light not buy sight,,could be deceviving ,look at and check to see if fuel pump relay is working if no fuel presure i,if u have presure in fuel rail ,replace the cranck shaft sensor
Jul 03, 2009 | 2000 Jeep Wrangler
2000 S10 4.3L Fuel pump stopped working out of the blue. We Put a new Fuel Pump in, new harnes to fuel pump, new fuel filter, new relay, new fuses in IGN C and ECM B fuses. Still the pump will not turn on....
Did you verify that the relay terminals have the appropriate signals to them?
ECM fuse B (20-amp) should provide power at all times to the orange wire of the fuel pump relay. The relay coil receives ground via the black wire, and relay coil gets power from the dark green/white wire. When the relay is closed, you should have battery power on the gray wire.
The relay trigger wire should have power from the dark green/white wire in terminal 1 of the Vehicle Control Module (VCM) connector for the first couple of seconds after they key is turned to run (to prime the system) and when the truck is running. Checking for all the appropriate signals at the relay is where I would start. That is after I checked for diagnostic codes.
Believe the fuel relay is the middle relay out of the three in the left rear of the glove box. Last thing is to hot wire the fuel pump if you can not get it scanned, see if the pump is bad unless your going to have a shop work on changing the fuel pump.
Good luck and hope this helps. keep me posted.
May 06, 2009 | 1999 GMC Safari
1995-1997 Chevy Suburban Ignition Starter Alarm switch Logo
344 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
