Question about HP Photosmart C8180 All-in-One InkJet Printer
Hp c8180 printer is frozen with a green screen showing 1 2 3 4 5 in the center of the screen. i unplug the power cord and sometimes it works but it always comes back. i called hp and the said they never heard of this.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
I have a HP C8180 that will not power on. It tries but just doesn't happen.
Assuming there is power in the power cord, pull the power cord out of the back of the c8180, wait one minute, put the cord back in, press the power button on the front of the c8180.
Apr 13, 2013 | HP Photosmart C8180 All-in-one -...
Tip
Ink System Failure 0xc18a0501 For HP C8180
NVM Reset : 1. Unplug the power cord from the back of the HP All-in-One.
2. Wait for the unit to go to the sleep mode. Wait for 60 seconds.
3. Press and hold Print Photos & Photo Fix
buttons simultaneously on the control panel; keep them pressed and reconnect the power cord to the All-in-One.
4. Continue pressing the buttons until the display goes blank or Reset shows on the control panel display.
Worked for me.
on Jun 14, 2010 | Office Equipment & Supplies
Tip
0x0xc18a0501 ink system failure C8180
NVM Reset :1. Unplug the power cord from the back of the HP All-in-One.
Worked for me.
How to perform nvm for hp photosmart c8180
1.) Power down printer normally or unplug printer, wait for 60 seconds.
2.) If powered down normally, plug printer in. Goto step #4.
3.) If not powered down normally, Perform step 4 then plug in & skip #5.
4.) Press and hold PRINT PHOTOS & RED EYE REMOVAL BUTTONS
5.) Press power button
6.) Continue holding buttons until you see an all black screen.
7.) Release buttons.
Nov 06, 2011 | HP Photosmart C8180 InkJet Printer
After changing an ink cartrige an error message read Ink System failure. Error Oxc18a0201 It tells me to turn off printer and turn back on using printer off button.
Ink system failures are a frequent issue. If turning the unit on and off doesn't help, try doing a reset. With the unit on, disconnect the USB cable from the back of the printer (and from the computer - not always required but it does help sometimes). Then remove the ink cartridges. When the screen shows Insert Cartridges, disconnect the power cord from the back of the printer. Unplugging the cord from the outlet may help. Wait 60 seconds and then plug in the power cord (first to the wall and then the unit). Turn on the printer if it doesn't turn on when the power cord is reconnected. Then reinsert the ink cartridges and close all doors on the product. Print a calibration page and scan the page if needed to complete the calilbration if prompted to print one. Reconnect the USB cord to both the computer and then the printer.
If this doesn't help, the printer needs service. If it is out of warranty, decide if the unit is worth the minimum $50 charge just to diagnose the problem and the cost to get the unit to a service center.
I hope this helps.
Jan 23, 2011 | HP Photosmart C8180 All-in-One InkJet...
Error code oxc18a01
The "Oxc18" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
May 28, 2010 | HP Photosmart C8180 All-in-One InkJet...
Sometimes unit won't shut down unless I pull the
press and hold the button and also check and see if all jobs are done.
Nov 29, 2009 | HP Photosmart C8180 InkJet Printer
1. Try to remove and reinstall the Ink Catridges. Be sure it is lock in place on the ink cartridge holder.
2. Turn off the Printer and unplug and replug the power adapter.
3. Uninstall and reinstall the printer driver.
Sep 24, 2009 | HP Office Equipment & Supplies
MY PRINTER WON'T PRINT ERROR CODE 0XC05D1281
First, be certain there are no tiny pieces of paper in your printer, left from the paper jam.
Then, you need to reset your printer - try:
1. Unplug from the power cord.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power check the functionality.
And, if the above doesn't fix:
1. Unplug the power cord from the back.
buttons simultaneously on the control panel; keep them pressed and reconnect the power cord.
Good luck.
Jul 04, 2009 | HP Photosmart C8180 InkJet Printer
Ink System Failure with error code: 0xc05d1281
I had the same problem and took Guru NinaE advice....1. Unplug power cord from back of printer while it is on. 2. Wait for 60 seconds after it is in sleep mode. 3. Press and hold "Print Photos" and "Red Eye Removal" at the same time and while holding the two buttons down, plug in the power cord into the back of the printer. 4. The printer display should go blank or Reset might show up on the display. When this happens, touch the ON button and the printer will reset itself.
May 20, 2009 | HP Photosmart C8180 InkJet Printer
HP Photosmart C8180 All-in-One InkJet Printer Logo
382 people viewed this question
Ben Johnson
