Kenmore 90 series
model is 11026912691
Washing machine will not stop running water.
The dual inlet water valve has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Hello Friend, Your problem is easily solved. You need to replace the water inlet valve. It's easy to replace the water inlet valve on your machine. First, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, you will be able to gain access to the water inlet valve. Simply remove the hose and wires from valve and replace with new one. Re-install the cabinet, control panel etc. This should solve your problem. Happy to help, Tim.
The water fills up and does not stop at the specified level. It will continue to fill up unless the knob is pushed back in. At this point, the washer does not go through the full cycle and the same thing happens on the rinse cycle.
I have the same problem!!! So I took it apart and didn't find anything wrong. Can you help?
clarifi some things with me do you mean water runs in and some how on its own with no motor noise the water then leaves machine?
