my kawasaki kvf automatic 4x4 will not start the green light does not light up when in neutral and the starter will not turn the red light will light up when in reverse what do i do . it starts whit the rope by hand bot its hard.my kawasaki kvf automatic 4x4 will not start the green light does not light up when in neutral and the starter will not turn the red light will light up when in reverse what do i do . it starts whit the rope by hand bot its hard.
AnonymousMar 29, 2014
kvfkvf
You can't post conmments that contain an email address.
wiring diagram for a 2000 kawasaki
Anon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." kawasaki prairie 300 wiring diagram Google Search
On the right hand side of the ATV just under the gear leaver, you will find a grey and black multiplugs, you will need to swap them.
Please see the link below.
KAWASAKI 360 PRAIRIE BELT RESET
on the KVF on the right side you will see 2 plugs, a grey and a black. conect the grey to black on both turn the key on for 2 minutes . turn the key off and then switch back to there proper position. this should work. The Check belt light comes on when its time for an oil change..
kvf
