The dryer is a Kenmore HE3. The clothes are not dry you have to start it again to get them dry. Last night it started beeping when the dryer was running.
Ok lets do one or two things,,first open the dryer and take a little rubbing alcohol and clean the two metal strips (moistyre sensor)if fabric softner or detergent gets on it it will trick the dryer and the time will drop...also check exhaust vent from back of dryer all the way out the house,,,onthejob
Does your model have sensor strips inside? Wash them with windex to remove any moisture barrier on them. They sense wetness and if they don't feel any wetness they make the control think them clothes is dry and it shuts down the dryer thinkin them clothes is dry.
First unplug your dryer from the electrical outlet. Next pull your dryer out from the wall. DIsconnect your flex outlet hose from the dryer and make sure it is not stopped up with lint etc. Next check the wall adapter to make sure it is clear of lint etc going to the outside of the house. If both of these are clear look inside the dryer outlet by looking in the tube where the flex hose was connected. You will need a flashligt to do this. If there is anything stopping it up remove it. If your dryer is getting hot but not drying there is probably something keeping the air from going out of the dryer to the outdoors.
REPL/ THERMAL FUSE LOCATED IN REAR (IF) LINT SCREEN ON TOP// OR LINT SCREEN INSIDE DRYER REMOVE METAL HOUSING WERE LINT SCREEN GOES INTO AND BEHIND THAT IS THERAML FUSE WHITE IN COLOR 2 RED WIRES CONNECT TOOOO......
I have the same problem. I set the dryer for 60 minutes, and it stops with 40 minutes left. It is a kenmore 80 series.
are the clothes dry
