Question about HP Pavilion dv1000 Notebook
Pavilion Dv1000 monitor won't show anything
Hi, I have a HP Pavillion DV1000. My computer seems to be running, but I can't see anything in the screen. I plugged it in at another monitor and I was able to see some data. However, when I tried it again in the other monitor, it showed windows xp loading up, but then it said "Power Saving Enable. The monitor will shut down in a few seconds".
Please help me.
  • 1 more comment
  • Anonymous Jan 07, 2009
    Huh? What does hybernation and standby have anything to do with my problem?
  • rogersbk Jan 25, 2009
    Im having the same problem. Please help.
  • jeffadams Mar 25, 2009
    I have a HP dv1000 that if I have AC plugged in everything works OK. If I try to boot up on battery I get no display even though the laptop boots up ok. I can boot up on AC and as soon as it gets past the windows splash screen I can unplug the AC and it will continue to display on battery.
  • HP Master
  • 32,281 Answers
Power management lets you reduce your Notebook power consumption. Your Notebook has two power management modes:
  • Hibernation is an energy-saving feature and safeguard that saves information to the hard drive, then turns off your Notebook. When you resume from Hibernation, your information returns to the screen where you were previously working. Your Notebook hibernates when the Power button is pressed, when the battery has little power left, or when your Notebook (operating on battery power) is in Sleep mode for more than one hour.
  • Sleep, also called Standby, is an energy-saving feature that reduces power to system components that are not being used. When Sleep is initiated, your information is saved in Random Access Memory (RAM), and the screen is cleared. Your Notebook is still on, but the display is blank. When you resume from Suspend, your information returns to the screen where you were previously working.
Automatically put your notebook into hibernation Windows can automatically put your computer into Hibernate mode after a specified period of inactivity. Or Windows can detect when your batteries are running low, and then automatically put your computer in Hibernate mode to save your work before the battery fails. NOTE: Using Power Options in Control Panel, you can adjust any power management option that your notebook's unique hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from what you see. Power Options automatically detects what is available on your computer and shows you only the options that you can control. To automatically put your computer into hibernation:
  1. In Category view, click Start , click Control Panel , click Performance and Maintenance , and then click Power Options . In Classic view, click Start , click Control Panel , and then click the Power Options icon.
  2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply . Figure 1: Enable hibernation check box Pavilion Dv1000 monitor won't show anything - c00035872.gif
  3. Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Manually put your notebook into hibernation This feature is available only on notebooks with the Windows XP operating system installed.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box. NOTE: If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start , and then click Turn Off Computer . In the Turn off computer dialog box, hold down the Shift key. The Stand By button will change to Hibernate. Click Hibernate .
Posted on Jan 06, 2009
I have formatted my computer and installed Windows xp and lost my drivers cd. can you help me getting audio drivers?
Please go to this site and select the operating system you are running. Audio drivers may be under Audio or chip set. Please note that Vista drivers should work with Windows 7. Hope this helps.
May 22, 2011 | HP Pavilion dv1000 Notebook
All the lights turn on on the hp pavilion dv1000, but the screen remains black. Almost as if there was no power going to the screen. I have tried reseating the RAM and the HD. Problem still remains. ...
Hook a external monitor to the video output on the back of the laptop, if okay! there is a LCD problem with the laptop screen, causes! bad inverter board, or back light. If both show black! causes are Video Graphics Card that is part of the motherboard.
Jan 10, 2011 | HP Pavilion dv1000 Notebook
The microphone is not working on my hp pavillion dv1000 laptop. I have checked all the volume controls etc but had no joy. What do I need to do to get it working
Hi
Have you checked in control panel Hardware and sound to see if anything is enabled in there
if you go to http://welcome.hp.com/country/uk/en/support.html you can down load audio drivers
or http://www.realtek.com.tw/Downloads you can download AC'97 or hd audio drivers
Oct 31, 2010 | HP Pavilion dv1000 Notebook
The screen remains black when computer is turned
maybe a hardware problem, on booting the pc, move the screen to every angle to see if there is a connection problem.
If so, then use your warranty if you have one.
Jun 13, 2010 | HP Pavilion dv1000 Notebook
The screen is black on start up. No image at all.
The dv1000's were a limited edition notebook withmany issues. the motherboard going on them was one of them. connect the motebook to a desktop monitor if you have one and simultaneously press Fn + F4 to use the monitor as a screen. If nothing happens begin crying. Time to buy a new laptop. You information is safe but you need an IDE/SATA PCI adapter to view the files on another computer. If you were using XP, i hope you didn't password protect it making it private. That will be problem number 2.
Mar 31, 2010 | HP Pavilion dv1000 Notebook
NO VIDEO ON HP DV1000
lcd inverter backlight lcd screen or video card probably bad
Apr 10, 2009 | HP Pavilion dv1000 Notebook
Screen Black can barely see images when boot up
well seems like the lcd has lost or the video card has an issue easy way to find out is to hook it up to a monitor and if the pitcure comes out fine then its your lcd screen and if it appears the same then its your video card.
Feb 09, 2009 | HP Pavilion dv1000 Notebook
Hp laptop issue
can u explain....only icons are not showing.??? what abt the start menu and all other applications.? does it work fine..?
Dec 22, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
741 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
