Question about HP DesignJet 1050c InkJet Printer
Need repair on a HP1055CM plotter in Toledo Ohio
There are 2 plastic lines that go from each ink cartrige to the print heads. One or both lines on the Cyan cartrige leaked/broke/cam lose, and sprayed blue ink everywhere. There is evidence the the red cartrige has leaked a little also.
    Genius:
  • 2,120 Answers
It is all one assembly. You will need to call a technician.
Posted on Jan 07, 2009
Random recurring buzzing sound.
Local results for television repairs Toledo Ohio Bing Local http://www.bing.com/search?q=television+repairs+Toledo+Ohio+&qs=n&form=QBRE&pq=television+repairs+toledo+ohio+&sc=0-14&sp=-1&sk=&cvid=047a43a19bff4df998a213e38cb181ce
Oct 28, 2015 | Televison & Video
Not print magenta or yellow
If you use CISS system. The problem may occur CIS. To solve these follow this proces:
1. put out cartrige from cartrige carrier
2. put a plastic seringe into the hole of the cartrige and try to out the ink from inside the cartrige ( mainly magenta or yellow)
3. Then run a head clean.
If result is No Try these:
1. Put off cartrige from cartrige Carrier
2. find out 4/6 stick inside the carrer
3. put a plastic seringe one after and push air on it.
4. After that take a seringe with ink and push it gentally into the stick.
I think you will be rid from your problem.
Thank you.
Jun 02, 2013 | Dell p713w AllInOne InkJet Printer
My Lexmark printer 1270 only prints in black and white although the colour cartriges have good ink levals. This has just started happening, it was happily printing in colour not long ago. Many thanks.
Jast go to print option. Then Mantainance. Then try to print a nozzale. If all the colour comes out properly ( with out dot or misline), your cartrige head is goog for print. If not, your printer cartrige head is block. To reque from the problem follow the proces:
1. Unpluge colour cartrige.
2. Try to clean the cartrige head with soft cloth and amonia gentaly.
3. Try to out the ink through the head nozzale pore by using shaking or gentaly swape by soft tissue.
4. Now put the cratrige head upon a soft tissue. ( ink will comes out). If not, repit stage 1-4 until ink come out.
Thank you
Jun 07, 2011 | Lexmark X1270 All-In-One InkJet Printer
Lines show up throughout print jobs
Your print heads most likely need to be cleaned.
When you don't use your ink carts for a while, when you get new ink carts that have been stored in warehouses for a number of months, or when you have refilled a slightly too dry ink cart, the print head nozzles on the bottom of the ink carts get clogged with dried ink. The printer head cleaner menu will not disolve the dried ink. Water will. Try this. Soak the bottom of the clogged ink cart in 1/2 inch of hot water for 15-30 minutes. Blot dry with clean paper towel(you should see the ink color on the towel). Retry.
Mar 07, 2011 | Dell 942 All-In-One InkJet Printer
Hi, (MX850) My blue ink has stopped printing. I
Performing Maintenance:
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
Step 1
Printing the Nozzle Check Pattern.
If lines are missing or if white streaks appear
Step 2
Print Head Cleaning.
If the problem is not resolved after performing Print Head Cleaning twice
After cleaning the Print Head, print and examine the nozzle check pattern (Step 1) again.
Step 3
Print Head Deep Cleaning.
If Print Head Deep Cleaning does not resolve the problem, turn off the machine and perform another Print Head Deep Cleaning after 24 hours. If the problem is still not resolved and if you are sure that the ink didn't run out, then the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
All the best.
Mar 11, 2010 | Canon PIXMA MX850 Multifunction Printer
Wont print it prints but no print comes out ink is ok
1st try to clean heads (printer cleaning function)
2nd see if any fresh ink droped on ink basket (inside right/left position.(normaly wrong ink density as non original ink cartriges, have 2 situations: ink too light as low quality ink, drops to much ink on ink basket, and flod and detiorate all metalics parts inside.
Or too heavy, and no ink will pass on print head holes).
3rd u can have the print heads, burnout (u can test on diagnostics tools on printers software), or send for repair, for local repair shop.
Nov 28, 2009 | Office Equipment & Supplies
The printer do not recognize the new replacement cartrige
I have many epson printer, some more than 5 years old. It's ok. some have printed more than 50.000pages, it's ok.
If Ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus R380 InkJet Photo Printer
I haven't used the printer in a while (about 6 months) then last week I turned it on and tried to use it. Went to print a test page and it went through the process but nothing came out on the paper. I...
Take out the cartriges and hold one at a time between your forefinger and thumb tightly. Hit your wrists together and see if ink comes out the bottom of the cartrige. Be careful not to mess ink on your clothes or carpet etc. This sharp "shock" will bleed the cartrige and hopefully the cartrige will work. Clean all messed ink from any contacts and the jet area of the cartrige before inserting back into the plotter.
Dec 14, 2008 | HP DesignJet 750c plus InkJet Printer
450c color problem
The 430 ID is B/W, you need to load the 450C driver to get color, renaming the driver isn't enough.
Oct 13, 2008 | HP DesignJet 450c InkJet Printer
Epson Photo R265 Lines every 2.5 cm
If its doing it on all types of paper despite of any setting on printer driver, chances are you are having a hardware issue with the product.
pls try this site: support.epson.com try use passcode; lock
only applies for US printers
pls dnt 4get to rate soln hope the site will help thanks
Apr 06, 2008 | Epson Stylus R265 InkJet Photo Printer
HP DesignJet 1050c InkJet Printer Logo
205 people viewed this question
Seeker5211
Seeker5211
