Question about HP Designjet 4500 Pass-Through Scanner
01.0:10 error on HP DesingJet 4500ps. - HP Designjet 4500 Pass-Through Scanner
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
I am trying to install the hp 4500 g510 to my computer. The options that I am getting are hp 4500 g510 a-f class, are they the same?10
no there not quite the same some versions of this model have a document feed - some don't ,- the product Number is what you should use to find the correct driver which could be one of the following-CB867A/CB877A -CM743A/CM744A-if you look at the serial number Sticker(with barcode) it will have one of these id tags on it - use this code in HP website to locate the correct driver
Jan 24, 2014 | HP Designjet 4500ps InkJet Printer
26.001 error hp 4000
26.0:01 is a bad contact in the Ink Supply System for the yellow ink cartridge. (This can be caused by using non HP OEM ink)
Check that the ISS to Cartridge cable is not damaged and is fully connected to the Ink Supply Tubes PCA.
You can also try switching the magenta contacts with the yellow contacts and see if the problem stays with the yellow, or you now have a magenta problem.
If the problem stays with the yellow, then you will need to replace the Ink Supply Tubes and Trailing Cable.
If the problem moves to the magenta, then you just need to repair or replace the contacts (may just need cleaned)
Good luck !
(My money is on bad compatible or refilled yellow ink cartridges)
Apr 12, 2013 | HP Designjet 4500ps InkJet Printer
Yellow printhead #1 error
change line sensor, because when the move carrige unit red lighth ok, but blue light epsent
Jul 26, 2012 | HP Designjet 4500ps InkJet Printer
How can irid of the hp product assistant poping up
here is a link that can help you get rid of the pop-up problem
hope it helps.
Mar 06, 2011 | HP Designjet 4500ps InkJet Printer
Desingjet T770 44 Pouces Hard Drive - The Code error on front panel is 47:01 (?) Thank you (I'm french and im not speak english, sorry)
Star wheel motor faulty,( to remove star wheel unit open left cover,formatter,power module,spitton)Normally most of the cases motor wont go gear unit pensions breakage observed mostly, replace star wheel motor unit or if you are tech guy you can make alteration see the snap shot how pinion got breakage..Find out metal pinion suitable for the same and fix it properly. 11_19_2011_4_07_20_am.jpg11_19_2011_4_07_49_am.jpg11_19_2011_4_08_22_am.jpgIf you feel this difficulty work just replace star wheel unit..
Jan 25, 2011 | HP Designjet T1100ps Printer
Hp desingjet 500 plus 24"
code error error 21:10 for hp designjet 500 24''
Dec 08, 2010 | HP DESIGNJET 500 InkJet Plotter Printer
Cannot free paper jammed in hp 4500 printer
you will need to be gentle because the paper will be blocking the sensors
Oct 15, 2010 | HP Designjet 4500ps InkJet Printer
I was printing on the HP4500 printer, when it stopped printing and said that I needed to replace the setup printheads. How long do the printheads last, do I need to clean them and put them back in or what?
The print heads do have a limited life, after a set number of ink drops have been printed the printer will stop until the print heads have been replaced. HP does not give the ield on print heads but usually every 2-3 years of normal printing can be had before replacement. The numbers you need are C5054, C5055, C5056 and C5057. Have have them in stock for shipping today if you need them. Email me if you need pricing or more information.
Corporate Computer
Aug 10, 2009 | HP Hewlett Packard Designjet 4500ps InkJet...
What causes an error 24.10 on a designjet 4500ps
System Error: 24:10
Broken bag detected in Ink Cartridge.
Corrective Action: Try the following:
�� Remove the Ink Cartridges and check for ink leakage in the ISS area.
�� Perform the "Bag Broken Recovery" Diagnostic (→ Page 4-51) to further
troubleshoot the error code.
Download the service manual at:
Jun 11, 2009 | HP Designjet 4500ps InkJet Printer
HP Designjet 4500 Pass-Through Scanner Logo
986 people viewed this question
Ben Johnson
