Error 404 comes up when I try to install my print shop 20
Had to install new hard drive then added my programs. I have a Dell computer demenssion4500... had print shop 20 before now it won't add, but can install my old printshop 15. I get an error message 404
  • 5,568 Answers
That message implies that the program has tried to reach an on line website, perhaps to register, but has failed because your connection was not active at that time. Try reinstalling it while connected.
Posted on Jan 07, 2009
Iam unable to download a workable program for my CM15A Computer 2 Way interface, When trying to download the CM15A version and install the program I always get an error code 404. Please help me get
The code 404 means the web page is not found.
This a X10 ActiveHome interface.connected by USB.
You can pick up the software from Software .
They also run a forum for CM15A help at AHP stopped communicationing with CM15A
Oct 31, 2014 | Computers & Internet
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
Re-downloaded The Print Shop and it looks like it downloaded properly but when I open it and try to work on a project in it the page stays blank. I.E. when I try to inserta picture or text box, the page...
has it worked before since you had the hard drive replaced?
if so do a system restore back to the last point it worked
otherwise go to controll panel and add and remove programs then uninstall the program
restart your computer and then re-install the program then it should work as long as you have it working on your other computer if you re-install it there should be no problem
let me know in more detail what is going on
it sounds like it has not installed properly so uninstall it then install again
also because you have a new hard drive you dont have a new computer
Feb 24, 2011 | Broderbund The Print Shop 20 Deluxe for PC
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Print shop is not installing
Do the following to re-install it again
Step 1. Go to your start menu and type into the SEARCH box RUN>a dialog box would come up
Step 2: Type REGEDIT>click on continue when it asks you to.
Step 3: Click the arrow beside HKEY_LOCAL_MACHINE>Click software and delete Print Shop> Try Installing the software again.
Aug 28, 2009 | Dell The Print Shop 20 Deluxe for PC
Epson 2200 stops after an inch or two of the print
Sounds a lot like spooler issues which may be related to your computer and the hard drive rather than the printer.
I'd recommend defragging your hard drive using:
START > All Programs > Accessories > System Tools > Disk Defragmenter
Run that on your hard drive partitions until it's finished (go do the laundry, ironing, clean the house while it works because it will just slow you down trying to work on it).
Also worth checking you have enough hard drive space and no disk errors... If you do I'd talk to your computer guy about cloning to a new drive with a bigger drive... It's a job of a couple of hours and drives are very cheap now for big capacities...
It can't hurt... but as I said, sounds a lot like a computer problem rather than a printer one.
Jan 30, 2009 | Epson Stylus 2200 InkJet Photo Printer
A disk read error occurred. the comp. said press ctrl+alt+del
The computer cannot find the operating system, the disk error message means it cannot find the hard disk, you most likely have a faulty hard disk or less likely a faulty disk controller.
You can test the hard disk by removing it and connecting it to a USB hard drive adapter and plug it into a working computer's USB port. If this computer cannot detect this drive as an external drive then you will know your hard drive is faulty ad you need to buy a new one and install Windows and programs etc..
Jan 25, 2009 | Dell Latitude C400 Notebook
Error unabling access to printshop pro 20
TPS Window Appears on Print Shop® Splash Screen Description Solution When attempting to open Print Shop® 20, a TPS window opens on the Print Shop® splash screen. The only option available in the small TPS window is to click OK. This issue occurs when Microsoft® .NET Framework 1.1 has been uninstalled. Reinstalling Microsoft® .NET Framework 1.1 will resolve this issue. View the remainder of this technical note for the instructions. Complete these steps:
  1. Close all windows and programs and return to the desktop.
    NOTE: If the TPS window is still open on the desktop, click OK. The Print Shop® splash screen will close.
  2. Insert the Print Shop® 20 DVD or Install CD into the proper drive.
  3. Double-click the My Computer icon. For Windows® XP, click Start and click My Computer.
  4. Right-click the CD/DVD icon that represents the drive where the disc was placed and click Open. The contents of the disc will display.
  5. Double-click the Setup folder.
  6. Double-click 1033dotnetfx.exe. The installation of Microsoft® .NET Framework 1.1 will begin.
  7. Review the License Agreement, click to place a dot by "I Accept" if the agreement is accepted and click Next.
  8. Click Install to install the Microsoft .NET Framework 1.1.
  9. When the "Installation of Microsoft .NET Framework 1.1 is complete" message appears on screen, click OK.
  10. Launch and use Print Shop® 20.
Dec 03, 2008 | Broderbund PrintShop Pro Publisher Deluxe...
Cleaning hard drive and re-installing all programs on Dell Inspir
Do a PC Restore (this will erase your files but original programs will remain just like you got it out of the box):
For Vista
1. Shutdown.
2. Power on.
3. On the Dell Screen, keep on tapping F8.
4. Repair your computer
5. Next
6. Choose your own Windows Logon Account
7. Type your password
8. Select "Dell Factory Image Restore"
For XP:
1. Shutdown.
2. Power on.
3. On the Dell Screen, keep on tapping CTRL+F11
4. Follow screen instructions.
Nov 25, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
