Question about Hoover U6660-900 WindTunnel Bagless Upright Vacuum
I have a hoover u6660-900, 3 yrs old. The drive support works OK in the forward motion but does not in the reverse motion. I don't mind using a screwdriver, but not sure where to start or look. Your thoughts? wally
Another, truly free web site.
Posted on Jan 07, 2009
Power drive doesn't work
Power Drive? If you are talking about a machine that drives forward when you push on the handle and drives in reverse when you pull on the handle, this machine does not have that feature.
Platinum Collection Cyclonic Bagless Upright
HOOVER Vacuum Parts Model UH70015
Oct 17, 2014 | Vacuums
Tip
Hoover Platinum Collection Carpet Cleaner with MaxExtract Technology making...
The cleaner does it's job well. Using on standard short carpet.
The problem so far is after 6-8 uses it started making a grinding noise when pulling backward.
Brushes still spinning just had the noise and the unit still functioned properly.
I only use it about every 3-4 months to clean 3 rooms.
The last use the noise got worse as it was making in forward and reverse motions.
The noise would usually start after using it for 5-10 minutes.
I figured it might be a slipping belt on the beaters and probably water was getting on the belt making it worse.
I removed the circular beater assy by just pulling it out.
Removed the round front beater by removing 3 screws, 2 at each end and one holding the belt guard on towards the middle. Once the beater is loose slide it out through the belt.
The front beater cogs for the belt had some black build up in between several cogs.
I cleaned the cogs very thoroughly, checked the belt for wear and checked the motor gear. They looked ok.
Assembled in reverse, did a quick dry test but didn't fill all the fluids to do a full test. That will have to wait till next time.
Please don't hold me accountable if you try this and break something, the cleaner is made mostly of plastic and the pieces can easily break. Don't try unless you are willing to take the risk, it may void warranty if it gets broken.
If problem still persists then will try using the 6 year warranty that it supposedly has... From what i've read it might be a pain getting it fixed under warranty.
Here are some visuals. http://s1139.photobucket.com/albums/n559/dmayfield1/Hoover/
fell free to contact for questions.
on May 27, 2012 | Hoover Vacuums
Does power drive wheels work both in forward and reverse and if they dont what is the solution? mine seems to work only in reverse??
The drive transmission works in both directions. If they do not, then the metal cable connection (under the hood) that connects the handlle grip to the transmission, may be slightly out of center adjustment.
Jan 01, 2010 | Hoover U6311-930 Power Drive Bagged...
Hoover model F8515 won' t **** up any water
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=703954
Hoover Model F8515 won' t **** up any water
posted by kevingao92 on Jun 24, 2008
It could be in reverse do you have any tips
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. the Hoover Model # F8515 works on the pull back to pickup the water and on the push forward you can dispense extra water or solution and the brushes will still scrub but on the pull back it dispenses, scrubs and also picks up the water all in one sweep, if not then contact you local vacuum dealer in your area, check the owner’s manual for the trouble shooting guide and or call the Hoover Factory cust serv @ the information listed below.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Carpet vacuum attachment quit working after sucking up a bedskirt. Bedskirt has been removed but carpet attachment will not work. My old vacuum had a reset button on the carpet attachment for use when...
I have a Hoover Conquest approx. 4 yrs old. The turbo head is not working Model No. PB4 230-240V AC 50Hz 200w CS4901N (N127) I have been trying to locate another one or another one similiar to fit my machine
Jun 12, 2008 | Hoover Vacuums
How do you replace the forward / reverse cable?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=661987 How do you replace the forward / reverse cable?
Posted by HANDYBILL on Jun 10, 2008
I don't know how the end fits back on the replacement cable.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 Windtunnel Vacuum. There is a hook on the bottom of the vacuum and @ the top by the handle as well. You may what to get a schematic or owner’s manual to see how they hook up because of the newer and different Model #’s for Hoover. The Hoover Self-Propelled works on when the handle is lower to a comfortable position then the self-propelled drive may just need and adjustment. There is a self-propelled rod that controls the self-propelled feature and it either needs adjustment or replacement or the part that hold it may be broken but either one can be fixed. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jun 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover self-propelled u6630-900 reverse not working
THe forward/reverse lever (made of plastic) possibly is broken. New part is about $10.00
Dec 12, 2007 | Hoover U6630-900 WindTunnel Bagless...
E drive problem. Self propelled feature drives in reverse, but not in forward.
This is basically the same problem with a Hoover power drive only the forward still drives albeit slowly and a slight "push" to keep it going. There has to be a common core type of drive failure !!
Feb 27, 2007 | Dirt Devil M087700SV Bagless Upright...
Hoover U6660-900 WindTunnel Bagless Upright Vacuum Logo
83 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
