Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
NO SUCTION AND CLEANING LIGHT IS NOT WORKING
I HAVE AN UPRIGHT KENMORE PROGRESSIVE THAT IS PURPLE AND PURCHASED ABOUT 7 TO 9 YEARS AGO. THE AGITATOR BRUSH IS WORKING AND THE VACUUM WILL PICKUP CRUMBS, BUT EVERYTHING FALLS OUT OF IT WHEN YOU TURN IT OFF. SO I THINK IT IS A SUCTION PROBLEM. CANNOT FIND A PLUG IN ANY OF THE HOSES. THE CLEAN LIGHT DOES NOT INDICATE CLEAN OR DIRTY EITHER.
  • 548 Answers
You have a dirty filter somewhere. Ignore the fact that the light hasn't come on because it is probably burned out. Check the bag and any filter areas for blockages - they are there. Take the hoses off, stretch them out and run a broom handle through them to check for problems there.
Posted on Jan 11, 2009
No suction motor comes on at all
It should be under warranty. Take it to a warranty repair center
Jan 17, 2014 | Kenmore 31913 Progressive Direct Drive...
We have the Kenmore progressive direct drive (bagless) and have had it for about 3 years. We have taken good care of it, and paid quite a bit for it hoping that it would last for a good long time. It has...
there has to be a clog or block somewhere - if the motor works, it should work did you try a wire coat hanger to go up in further where you cannot see?
Bets regards
Ck
Jan 15, 2011 | Kenmore Progressive Bagless Upright with...
Kenmore InteliClean 116.35923502 Two, I believe unrelated, problems. 1) The InteliClean sensor lights stay amber and red even when the machine is in the upright position and the suction line is...
I had the same problem with the amber inteliclean light continually on. I found the problem to be in the plastic housing that connects the suction hose to the back of the upright section. You have to remove three screws and gently pull the hose housing off the vacuum. Inside I found a hairy clump that was caught on the inside of the hose. The optical "dirt sensor" is just inside the fitting on the upright section. When dirt or other stuff blocks the optical path of the sensors, the amber light will illuminate. My vacuum had an uneven cut on the hose which caused a snag point for hair, dirt and debris. Once this was removed, the vacuum worked like new.
Regarding the roller, this unit has an integrated motor in the roller. I would guess that you will need to take it apart, and hopefully only clean it up. If you need bearings, that will likely be expensive.
Dec 24, 2010 | Kenmore Progressive Bagless Upright with...
I have a Kenmore Progressive Upright Vacuum - Purple, and it worked just fine. I emptied the canister (like always) and put it back in place. I turned on the vacuum to it immediately shutting down (motor)...
Make sure that something didn't fall into the fan assembly in the base when the canister was removed. The motor should have an overload reset switch. Try moving the motor manually (power plug out) to make sure that it isn't bound up.
Dec 24, 2009 | Kenmore Progressive Bagless Upright with...
I have a Kenmore Progressive Inteleclean Upright vacuum cleaner (with Bag) . It has good suction only through the hose now and none through the bottom for cleaning carpets. and, there is a noise like it...
Theres a little bendable neck that hose with suction plugs into. Thats the one thats clogged. You will have to fish it out by taking off the roller and clearing the clog.
Sep 22, 2009 | Kenmore Progressive Bagless Upright with...
Loud noise from Kenmore Progressive Bagless Inteli-Clean
Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk.
Jul 04, 2009 | Kenmore Progressive Bagless Upright with...
Only suction to attachments
Something is stuck in the throat of the floor head, between the brushes that turn, and where the hose connects at one side (usually right hand side) of the floor head.
Reply back what you find.
Feb 04, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Kenmore Progressive 36932 Upright Vacuum
It's located inside the vacuum kind of behind the where the dirt is collected. You can open and clean but this is probably not necessary. You probably vacuum very fine dust that is hard to remove from the system.
Try replacing or cleaning all filters and letting the vaccum run for a few minutes without moving. Agitator off of course.
Jun 21, 2008 | Kenmore Progressive Bagless Upright with...
Getting suction to use attachments
When the vacuum is in the upright position, it should give you suction thru the hose.
Dec 02, 2007 | Kenmore 31913 Progressive Direct Drive...
My vacuum is not sucking at all.....
I took out the air flow filter at the back of the vacuum and turned it on, somehow the clog cleared. Then I put the filter back in and it works perfectly! Barb
Mar 01, 2007 | Kenmore 35912 / 35913 Progressive Upright...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
193 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
