Question about Refrigerators
Brand new freezer not starting
I have bought a brand new Hotpoint Fridge Freezer. The Green power light comes on ..the compressor starts and stops after 20 seconds. Tried this 3 times with similar result. It had stood for an hour whilst i rehung the door initially. Manual said 3 hours!! I missed reading that bit. any answers???
  • ianrodie Jan 07, 2009
    I used several mains sockets all of which are working. But thanks all the same
    Sorry,..not used this service before..your comment was helpful and sorry for not giving all info...i had checked all the obvious things eg fuses.
  • 1,543 Answers
You may have plugged your freezer into a bad receptacle, which is not providing the proper voltage. (usually due to a loose wire or bad contacts in the receptacle.) After letting the unit sit for at least 10 minutes, plug it into a different outlet (preferably on a different breaker). You can use a heavy gauge (like 14 or 12 gauge) extension cord for the test. If it starts and runs, fix your original receptacle / breaker / wiring. If still the same results (compressor not starting), call for warranty service.
Posted on Jan 06, 2009
  • Carl Schulzetenberg
    Carl Schulzetenberg Jan 07, 2009
    A "Thanks for Trying" rating is really a slam in Fix-Ya, and drops my rating down. I think with the limited info you gave (didn't bother saying that you had tried other outlets) the determination to then call for warranty service should have at least rated a "Helpfull". Please let me know what your warranty service tech finds with this unit. (This may be helpfull for future questions) Thanks.
Our Hotpoint Freezer, although only 18mts old stopped working.
quite possibly the unit lost freon and then the compressor failed , call a repairman
Nov 30, 2015 | Hotpoint Refrigerators
Red light on bosh classixx fridge freezer
sounds like compressor has failed to start and overload is triggered(red light) it could be start capacitor fault or overload itself faulty .
If both of these items ok and compressor has power to it then compressor will require replacing.when you switch of refrigeration equipement the oil in the system will drain down to the lowest point and thats normally compressor and if its filled up the suction side of compressor it will cause compressor to lock up (hydraulic)
Mar 14, 2012 | Bosch Freezers
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge freezer hotpoint ffa70 - The freezer overheat light came on and the freezer stopped working, followed by the fridge not working about 4 days later. Now it just doesnt work at all!
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 06, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint Mistral Fridge freezer no Power Issue
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Dec 11, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Fridge freezer has stopped working
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Jul 01, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge freezer not working after power cut
if its a ge i would say itsyour main board not compressor boards about 200
Mar 19, 2009 | Refrigerators
Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Oct 03, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
