Question about Dell Inspiron 5150 Notebook
Another monitor problem
Another problem with my screen. After turning the laptop on, the screen flashes gray and black a few times, and then begins alternating red, green, blue, white, and black over and over again. Rebooting doesn't do a thing. Not sure what to do with it. The computer is three years old, and has traveled a bit, so it has had a few bumps now and again. Any ideas about this? Thanks
  • Benoit Deeg May 27, 2007
    thanks, will try and have someone take a look at it.
  • Benoit Deeg May 29, 2007
    Oh well, its busted. Other than the hard drive and RAM, is there anything else worth pulling out before I dispose of it?
  • 85 Answers
It can be that it crashed or has suffered internal damage to the mother board or graphics card
-CG
Posted on Jan 22, 2009
    Genius:
  • 2,985 Answers
Its a graphics card thing or a connector loose. If graphics then as it is integrated with the main board there is nothing that can be done. If it is a loose connector- well can you or any one take a look see A repair shop perhaps?
Posted on May 27, 2007
  • john ash
    john ash May 29, 2007
    CD drive prbably- but these do take a bashing to probably best ti let it go with the rest.
SOURCE:
Xps m1530
Sounds like your video chip or your backlight. Hook up an external monitor. Does it stay on or the same results.? How long before it goes off/BLACK ???
Jul 05, 2013 | Computers & Internet
One of the two monitors will cease displaying screen image and begin rotating between a BLACK/WHITE/GRAY/Primary Color Bars every other second following a few minutes after start up. Have tried Restar
It might be the input from the graphics card. Try swapping the two monitors' feeds to see if the problem is with the monitor or the card. The monitor seems to be going into a screensaver mode since there's no signal. The flashing light could mean there's a power supply problem, or no signal.
Oct 15, 2017 | DoubleSight Displays Computers & Internet
Samsung monitor blue flashing light, black screen
The picture board of your monitor has developed fault. That is why the screen is black.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity, because the fault is not something you can fix in other not to complicate issues..
The repairer will help diagnose and replace the faulty picture board and your monitor is back and better.
Take care.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
A horizontal (2mm wide gray line) appears along my screen steady.
try plugging into an external monitor.. if the screen looks ok then it is most likely the laptop LCD screen is bad.. had the same thing on a HP laptop .. replaced the screen and all was well again with the world...
Dec 23, 2008 | Computers & Internet
Happy turkey day, I have a westinghouse lcm-19w4,when I turn it on the screen flashes gray horizontal lines in the middle of the screen for a second then goes black. this happens a couple times then the...
You either have a hardware problem with your video card. ( may have pop out of socket when you plug in the monitor) or the cable is not allow communication to the monitor. As long as the amber light comes on you know you have power so focud on data cables and hardware.
Nov 27, 2008 | Computers & Internet
Monitor image flashes off and on
Sounds like you've done all the trouble shooting. If you just need that extra nudge, I would agree... it sounds like you'll be needing to shop for a new monitor.
Jun 29, 2008 | Dell E153FP 15" LCD Monitor
Screen flickers and then turns gray
Access BIOS and test if the flickering continues.
If not, it is a Software problem, do a full system recovery
If yes, it is a hardware issue, better contact Toshiba tech support to have your LCD repaired if you are still in warranty.
If your not in warranty, you need to check out the LCD harness that might have been loosely connected.
Hope this helps...
May 12, 2008 | Toshiba Satellite A135 Notebook
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Monitor Flashes Gray, Then nothing
try to decrease the screen resolution. try to 640 x 480 then raise to 800 x 600. for old CRT monitor maybe have a problem with 1024 x 768. if decrease not work, then you might have a hardware problem, you need to purchase a new one. try the test first. maybe you can test with your monitor of your friends first :-), if work, you need to purchase a new one.
Feb 17, 2008 | Acer AL1916W 19" LCD Monitor
Dell Inspiron 5150 Notebook Logo
161 people viewed this question
Clive
Clive
Alun Cox
