My new printer suddenly stopped making a connection between the printer and the item to be printed.  Printer says "Printer Ready" but does not show the item to be printed in the queue.  Cedar
    Genius:
  • 1,124 Answers
Disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Posted on Jan 06, 2009
Not showing ready on the display
To help you troubleshoot the issue, please follow the steps given below:
- Make sure the printer top cover or printer door is closed properly.
- Make sure printer power connections are turned ON.
- Make sure there is no print job stuck in queue, if yes then you need to cancel all the print job from queue and check printer shows ready to print display.
If issue persists, please update the printer driver from your printer manufacturer website.
GuruAid.com
May 31, 2016 | Office Equipment & Supplies
Printer won't print. I went to printer and it says there are 9 items to br pringted in queue but they won't print Printer says it is ready
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
Jun 10, 2011 | Lexmark X2670 All-In-One Printer
After hitting print button,dialog box comes up printing, but there is nothing printing. Per control panel Printers & faxes everything is ok shows D2600 printer ready, per box item in que is printing
Hi there please try these.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 03, 2011 | HP Color LaserJet 2600n Printer
I just got a new computer with windows vista installed when i went to use my printer it keeps saying printer not commuciating with the coumpter
hello,
plug your printer to a power supply, connect the printer to the computer, make sure it is screwed properly, the computer detects it as a new hardware, install the new hardware hen it is ready for use.
when you are about to print, you select the item you want to print, then you right click and select 'print' from the options, select the type of printer you are about to use and it is ready for use.
Jan 03, 2010 | Lexmark C533DN InkJet Printer
I replaced the shuttle and need to do the phasing adjustment. Can you tell me how?
IMPORTANT The printer must be printing the Phase pattern of “H’s” when the Phasing Value is changed, or the New Phasing Value will not be written into NVRAM. If the value is changed when not printing, the printer will return to its default phasing
value when powered off then back on.
1. Install the ribbon.
2. Load full width (136 column) paper.
3. Power on the printer and set top of form.
4. Press Stop to put the printer into NOT READY mode.
5. Press Scroll + Scroll to unlock the Enter key.
6. Press Scroll + Scroll + Return + Enter to enter the CE Tests menu. (Press all four keys at the same time.)
7. The display will show “SERVICE / PRINTER MECHANISM TESTS”, the first menu item. Press Enter to enter the
mechanism tests menu.
8. Press Scrollor Scrolluntil
“PRINTER MECHANISM TESTS / HAMMER PHASING” is on the display.
9. Press Enter. The printer begins printing all H’s, each line preceded by the phasing index number.
10. Press Return. The display will show
“SERVICE / PRINTER MECHANISM TESTS”.
11. Press Scroll or Scroll until “SERVICE / HAMMER PHASE VALUE” is on the display.
12. Press Enter. The top line of the display will show
“HAMMER PHASE VALUE” and the bottom line will show the current phasing index number.
13. Press Enter. The phasing index (followed by an asterisk) will move up to the top line of the display.
14. Press Scroll or Scroll to increase or decrease the phasing index, then press Enter to activate the value as it prints.
Continue to increase or decrease the phasing index until the pattern of H’s appears.
15. When the print pattern is acceptable, press Stop. Printing stops, and the printer automatically enters the current phase
index value into NVRAM. The display shows “NOT READY”.
16. Press Scroll + Scroll to lock the Enter key.
17. Close the printer cover. Press Start to put the printer into READY mode.
NOTE: If you changed the phasing value, power down the printer, remove the shuttle cover, and write the new phase value on
the aluminum shuttle casting.
Oct 06, 2009 | IBM 6400 Matrix Printer
CX5500 wont print!!
Your printer is not ready yet because you didn't see yet 4 colors Cyan, Magenta, Yellow, Black.
If this 4 colors are showed then your printer is online but if not it all shaded grey.
If still have a problem exist, insert the cartridge properly or calibrate it. Such problem like this are due to cartridge not inserted properly. I have one this kind of printer in my house CX5500, it's cool.
Power On & Power Off is the best result on this.
Sep 15, 2009 | Office Equipment & Supplies
Won't print document
i believe this is a usb printer if so if you have turned off the pc you may need to go into the printer and faxes part of the start menu and open it up go to properties and make sure that the printer is set to print online not offline and usb connections can sometimes reset otherwise go to the control panel and see how many times your printer is listed delete all but the one that is listed online and try printing from that one set it as default
best luck
Aug 27, 2008 | Lexmark X4270 All-In-One InkJet Printer
After setting as default printer Lexmark X2250 just stopped printing and showing up in printer section
Uninstall the driver , and install again.
The problem will be resolved.
Uninstall the driver: Start\Control Panel\ Programs and Features\Remove all the lexmark items there.
Mar 06, 2008 | Lexmark X2250 All-In-One InkJet Printer
Printing problem
I also own an HP D2360. I had the same problem with eyang and vinerc. I brought the printer to a computer technician and he told me that my color cartridge is busted and needs to be replaced. I bought
a new color cartridge and presto! My printer is working fine.
Oct 14, 2007 | HP Deskjet D2360 InkJet Printer
Epson Stylus C60 InkJet Printer will not print
First  go to your pc and click on file, print when the window opens does it show your printer in there? is it set to THAT printer?  does it show as being Ready?
If not re download the driver,  then click on File, Print, right click on your printer and set as default.
Next double click on My Computer, ( or click on Start, Control panel, printers and faxes, put your mouse over your printer it should say Ready, if not then change the cable
Sep 20, 2007 | Epson Stylus C60 InkJet Printer
115 people viewed this question
k24674
jasbo
jasbo
