Question about Creative Labs MuVo Micro N200 MP3 Player
Creative MuVo Micro N200
The screen for viewing on my device is really funky. Basically the display is cut down the middle. The top half of the words are displayed on the bottom and the bottom half of the words are displayed in the top half of the screen. Any idea how to fix this? I've deleted all tracks off the device and it didn't fix it. I've also taken out the battery and replaced after 10 seconds. In addition, I've reloaded all drivers and firmware and still it isn't fixed. Thanks for any help you can provide.
    President:
  • 4,402 Answers
You have a bad displayor the connector to the display is comming off.
Posted on Jan 21, 2008
Tried turning it on. It says there is no music, but there is.
Maybe it's time for you to upgrade to a new mp3 player. I guess the regular one you have right now is probably old. If not old, try to see if you can get the manufacturer that owns the product to see if they can fix the issue. If they are not able to assist, then maybe you can troubleshoot it.
May 12, 2017 | Creative Labs MuVo Micro N200 MP3 Player
Help!!!
It can also be caused by transferring DRM (Digital Rights Management) encoded media files via the drag and drop method. It is recommended that you use the drag and drop method to transfer audio files that are not encoded with DRM. If in doubt, use either Creative MediaSource Organizer or Windows Media Player to transfer your files.
To resolve this difficulty, we recommend that you format the player and transfer the content again. You can also download and install the latest firmware, and select the Format Data Area option during firmware update.
To format a MuVo player, connect it to a USB port on your PC. Open the Windows Explorer, and locate the Removable Drive listing and right click on it. Select Format, and choose FAT instead of FAT32 or NTFS. After the formatting is complete, make sure that you stop your player before disconnecting it from your PC (see above)
To update or reload the firmware for a MuVo player, select the model of your player from below.
This firmware upgrade only works with Creative MuVo Micro N200 players. Do not install this upgrade to other players.
You will lose all content in your player when you install the firmware. Back up any audio or data files in your player to your computer before upgrading the firmware.
Before installing the firmware, please complete the following procedures:
  1. Download the latest device driver if you have not installed any drivers for your player. The file name is MStorage_PCDRV_LB_1_07_00_250.exe.
  2. Connect your player to your PC.
  3. Close all active applications (for example, Internet Explorer, Windows Explorer, or Windows Media Player etc), as well as background applications such as Norton anti-virus applications.
  4. Double click on the file MStorage_PCDRV_LB_1_07_00_250 to install it. Follow the instructions on the screen.
To install the firmware for your player, follow the procedures below:
  1. Download the firmware update, MuVoN200_PCFW_LF_1_20_04.exe to your hard drive.
  2. Connect your player to your PC if it is not already connected.
  3. Double click the firmware upgrade file.
  4. When prompted to set your player in Recovery mode, disconnect your player from your PC.
  5. Remove the battery from the player, press and hold the Play button while connecting the player to the USB port.
  6. Continue to hold the Play button for about 10 seconds after your player is connected to the USB port.
  7. When the Find New Hardware dialog box appears on your PC screen, release the Play button.
  8. If this is the first time a player is installed as Player Recovery Device, Windows will find a Player Recovery Device (or USB Device), and prompt you for drivers. Click on No , and select Do not search. I will choose the driver to install. Windows will install the necessary drivers automatically.
  9. Double click on the downloaded firmware again (MuVoN200_PCFW_LF_1_20_04.exe) to update the player's firmware.
  10. During the firmware update process, make sure to check the box next to Format Data Area under Download options.
Jan 21, 2008 | Creative Labs MuVo Micro N200 MP3 Player
Cant use my mic
do you have the latest firmware and are you using new batties?
http://us.creative.com/support/downloads/welcome.asp?action=next
Nov 21, 2007 | Creative Labs MuVo Micro N200 MP3 Player
Error
Did you format it properly?
Usually MP3 Players are to be formatted with the FAT32 File System. This can be easily done on Windows.
Simply connect the Mp3 Player to your computer via the USB. Then Windows should be able to detect it just fine. Go to My Computer and right clock on the new device (that is the MP3 Player) and select "Format".
Format as FAT32 and try again.
PS: You may want to backup all data (if that is possible) before you attempt this Format thing.
Oct 03, 2007 | Creative Labs MuVo Micro N200 MP3 Player
File system error
hi! all,
when i connect my muvo n200 256MB, it show h: is not accesible. The request could not be performed because of an I/O device. Please help what can be done. please reply
sibinkumar
Mumbai
Aug 01, 2007 | Creative Labs MuVo Micro N200 MP3 Player
MuVo N200 1 GB
look for a tiny pinhole and insert a pin while powered up to reset the device
May 27, 2007 | Creative Labs MuVo Micro N200 MP3 Player
Muvo v 100 mp3
May 06, 2007 | Creative Labs MuVo Micro N200 MP3 Player
A problem with turning on . . .
Jan 27, 2007 | Creative Labs MuVo Micro N200 MP3 Player
Creative MuVo N200 512 MB MP3 Player
If you've tryed to leave out the batterys more then a day or so?? if not try it BUT if this dosent help it may be time to get a new mp3 . Sorry but there are no real user serviceable parts inside of these puppies. Good Luck
May 02, 2006 | Creative Labs MuVo Micro N200 MP3 Player
Creative Labs MuVo Micro N200 MP3 Player Logo
97 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
