Question about AT&T Blackberry Curve 8300 Smartphone
Keypad wont respond
Screen went blank, took out battery, reinserted and screen reappeared but when I push the keys nothing happens, even track ball.
    Brigadier General:
  • 7,752 Answers
You need to reflash the OS
When your device fails to start, it show one of these symptoms:
1. Totally dead.
2. Trying to restart, LED activity only.
3. Failed to start, a white screen with an error message.
__________________________________________________ ________
1. Physical damage, water is the worst enemy of delicate electronic device. Try drying it with a desiccant and replacing the battery. If there is no activity, you can still try the last ditch technique, nothing to loose anyway.
2. Your device is not able to start, something has gone wrong and the OS is corrupt.
3. Geeks call this an "Uncaught exception error". That is a polite way of saying, the last thread has terminated, the OS has halted because it is corrupt.
In many cases, the Application Loader can be used from Desktop Manager or Windows.
If that fails to connect, there is one final solution. Go Old Skool ...
The good news, starting from scratch, you will be back in service in a couple of hours. keypad wont respond - biggrin.gif
Note: Windows 7 beta is not compatible with these instructions.
1. ...
2. You need to install a BlackBerry OS file that is specific to your device. The original version, as supplied by the carrier, is the safe choice, but you can use any model specific version.
3. Once the OS has been installed, you have to prepare it for the device.
Select Start / Computer and select the Drive C: Icon.
Open Program Files / Common Files / Research in Motion / AppLoader.
Navigate to the bottom and delete the file Vendor.XML file.
4. You are now ready to restore your device. Verify that BlackBerry Desktop Manager is NOT running. Plug the device directly into the computer's USB port.
We are about to venture into the bowls of the beast. Windows is not suitable for this job, we are going to invoke the Command line interface with an option switch.
Windows XP: Start / Run... / Command
Posted on Feb 04, 2010
My TI-83 PLUS wont turn on
Remove one battery from the calculator and then press and hold down the CLEAR key while re-installing the battery. While continuing to hold down the CLEAR key, press and hold down the ON key. If this doesn't work, then hold DEL and then ON. If unsuccessful, remove all the batteries, including the lithium watch battery, and leave the calculator like that for a while.
This is documented in the TI-83 Plus Guidebook, but unfortunately, not many people know about it.
If that doesn't work, send it to TI for repair. They probably won't even charge you!
Mar 20, 2017 | Texas Instruments TI-83 Plus Calculator
All of a sudden my keys on blackberry curve will not work, side buttons (camera, etc) ) WILL NOT RESPOND, all it will do is boot up, i can scroll up and down but cant click on anything....i didnt get it...
Hi
sinc your side key also not working seems like your phone is moisture damge from track ball area.
IF your keypad lights up that means the keypad is not loose.If not then your keypad connections are loose.
you may have use the track ball with your hand wet that cause this problem.
basically you need to clean your phone from inside.
thank you.
Sep 22, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry keyboard problem
Hello everyone, this problem is cause by humidity, it is solve leaving your blackberrry rest for a while without battery in a dry place. Blackberry has not mention it but it happens a lot, and it only needs a little quantity of your own sweat to put you in troubles.
Dec 28, 2008 | Microsoft Office Outlook 2003 for PC
Nothing transfered from the lens (ccd) to the screen/memory card
Greetings Maltheskalle,
Units that experience water damage are normally irrepairable even after drying out. I would take it to a qualified repair center and have them give you an estimate on repairing the unit. You may find that replacing the camera is more economical than repairing it.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 10, 2008 | Kodak EasyShare CX7525 Digital Camera
Touch screen do not respond
could you explain in detail what s happening with your phone??
u said that ur phone cannot be unlocked...but then u say that it happens typically during nights...do u mind elaborating?
May 10, 2008 | HTC P3300 Smartphone
Screen is now white with the text --download started--, emergency @ usb.
Holding down the camera button, (samsung a870), while inserting the battery got this one working again.
Feb 27, 2008 | Samsung SCH-a870 Cellular Phone
Canon sure shot 90u
Take the battery out then push some buttons - the zoom buttons or the release button - til the LCD goes blank. This sometimes resets the circuit if there is really no problem. Then reinsert the battery and try again. If the H reappears, there is a problem with your zoom. It'll have to go to a repair shop.
Nov 30, 2006 | Canon Sure Shot 90U 35mm Point and Shoot...
AT&T Blackberry Curve 8300 Smartphone Logo
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
