5d is: It denotes suds lock (overdose of detergent dectected during the
wash cycle).
Chances are you just put too much detergent in, or
maybe the wrong detergent - make sure you're using the HE detergent.
These codes and more details are printed on the service technician
diagnostic manual that is affixed to the inside of the washer's front
panel.
Unplug your washer, and unscrew the three 1/4" socket
screws at the bottom of the washer. The manual should be taped to the
back of the panel, and the code and some recommended procedures will be
right inside.
The error you have displayed is actually "SD", which is a SUDS detect
error. This usually an indication of a restriction somewhere in the
drainage system, a failed drain pump, you are using too much detergent,
or you are using the wrong type of detergent. The following link
explains the error in more detail and how to correct:
http://www.fixya.com/support/r3608687-sud_errorNOTE:
If these preliminary measures do not correct your problem, you may
have to replace the drain pump. It does not take much to damage the
pump impeller or motor. Since the error code can be generated if the
drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at
the required volume, the error code will continue to appear until the
pump is replaced.
COURTESY:jsrock - A senior expert of fixya....
Please
donot forget to rate and accept my answer...
