Question about Sony STR-DE697 Receiver
Protect message when I turn on the receiver
Each time I turn on my set, I get the protect message. I've reconnected all my speaker wires and that hasn't helped. I don't blare my speakers, and the set is only 3 yrs old. The receiver has plenty of air space above it. Worked fine until this week. I'm not very knowledgable about electronics and live far from any dealers/repair services, so I hope someone can offer a solution. Thanks. Barbara
  • 1 more comment
  • Barbara Holm May 30, 2007
    Stereo suddenly started working again for no apparent reason. Since it seems now to be an intermittent problem, i'll have to watch for some sort of pattern before trying for a fix.
  • jmck50 Nov 20, 2007
    The Protection message appears when lots of action sound (data) has to be processed through all of speakers and after 4 seconds, it turns off the receiver.
    Not sure of what's happening. I've checked all general things such as air circulation, wiring shorts, power tolerence and I'm not sure of why this is shutting down.
  • tfron Nov 07, 2008
    Does anyone know how to fix this. I opened up the deck and replaced the fuse because I had no visual wording on the screen. I now have wording but it says protect. I have connected and reconnected the wiring as well as assured there is plenty of ventilation and the top has been replaced. Does anyone suggest what I should do next to fix this problem?
  • 883 Answers
Call 800-488-7669 for tech support
Posted on May 27, 2007
'protect' shows on the screen of my sony str-dg510 receiver and the power shuts off. What's this about? Also, how do you connect an ipod to this receiver.
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Jun 01, 2011 | Sony STR-DG510 Receiver
I have a Sony STR-DE597 stereo and when I turned it on this morning, the receiver flashed PROTECT for about 5 seconds and shut off. I turned it back on just to have it flash PROTECT again and shut itself...
Jan 14, 2011 | Audio Players & Recorders
No sound , display shows digital protect
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
Jun 09, 2010 | Sony STR-DE685 Receiver
Sony STR-D665 receiver display flashes "PROTECT"
Jun 07, 2010 | Sony STR-D665 Receiver
Was given an Onkyo TX 8410 and was told that it doesn't work, when you turn it on the "Protect" message immediately comes on. What could be the causes and how can I try to fix it?
Jun 06, 2010 | Onkyo TX-8410 Receiver
I am getting an "OVERLOAD" message on my unit. It keeps turning on and off. The unit only works on a very low volume setting.
May 29, 2010 | Pioneer VSX-456 Receiver
PROTECT MESSAGE
It senses an error or problem and shuts down. Try disconnecting all the cables and wires attached to it. Try it again. If it still shows protect message, it is an internal fault and requires a repair shop. If it clears up, then the problem may be a shorted speaker wire. Correct the short when reconnecting the speakers.
Mar 08, 2010 | Sony STR-DE545 Receiver
GOES TO PROTECT WHEN WE TRY TO PLAY THE CD, TAPE OR RECORD PLAYER
Receiver say's "Protect" or turns on then off posted on Dec 13, 2009
MessageRate.ThreadID = 3632423; MessageRate.ProductID = 0; c81ea4d.jpg smarthome2
Rank: Guru
Rating: 88%, 432 votes
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire2_bing.gif. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers2_bing.gif one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers2_bing.gif) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Feb 27, 2010 | Sony STR-DE535 Receiver
My sony str-de485 is displaying a "protect" on the screen it won't let me hear musice or cd's
Rank: Guru
Feb 26, 2010 | Sony STR-DE485 Receiver
Protect appears on display on kenwood kdc 3034
Disconnect all the speaker wires at the receiver and turn it back on. If itdoesn't go into protect mode, your receiver is ok.
Reconnect the speakers one at a time being sure to turn the receiver off each time you connect a speaker and turn the receiver on until your receiver goes into protection mode again.
When it goes into protect mode again, the last speaker you connected has a problem. Trace the speaker's wire to the speaker looking for cuts or shorts along the way.
If you have a multimeter, switch itto ohms and check the speaker for a dead short, if you show a dead short you have a blownspeaker. Hope this helps.
--Matt
Oct 07, 2009 | Kenwood Car Audio & Video
Sony STR-DE697 Receiver Logo
209 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
