Question about Lexmark JetPrinter Z25 InkJet Color Printer
PrinteInkjet download error
I have a lexmark z52 printer. It was working fine until one day I tried to print something off the internet. I got message that said "error found when printing doc."Inkjet Download" to LPT1". I don't know what that means. I have tried everything I can think of to fix the problem. I have unplugged the printer from the outlet and from the modem. I have unistalled the printer and reinstalled it from the disk. My operating system is Windows 2000 just in case that matters. Please help. I have benn with out a printer for a couple of weeks now.
    Genius:
  • 1,124 Answers
Check the printer ports, it is probably that your printer is connected to a wrong port. You have to go to printer properties and then to "Ports" If your printer is connected via LPT1 this port must be selected or if your printer is connected via USB port the "Virtual USB port" must be selected.
Posted on Jan 06, 2009
My lexmark x3470 wont recognise compatible ink Cartridges any know of a way round this
If the ink cartridges you purchased are not Lexmark - that could be the problem. I used to have a Lexmark printer and I did the same thing - I purchased ink cartridges that were compatible but not Lexmark brand. Everything seemed fine until I tried to print and then I would get the same error sign and low ink message and it would not print. I kept thinking I was doing something else wrong and tried everything. In the end I broke down and got ink cartridges from Lexmark and that solved the problem. Now I have a Brother printer and I never buy anything other than Brother ink cartridges because I'm always afraid of that same thing happening again. I wish I knew which printers WOULD accept those non name brand ink cartridges, but thus far I do not know of any printers that do. Hope this helps you.
Mar 24, 2012 | Lexmark X3470 All-In-One InkJet Printer
Tip
HELP!!! A few days ago I was using my printer and it was doing okay, then all of...
Greetings,
This information is intended for those of you that are getting support from the Fixya.com expert community, for your printer. There are a few things you may wish to consider, prior to posting a request for assistance.
A. It's absolutely vital that you use the correct model number and maker's name for your request. Without that, no expert will be able to access their extensive information pool of techniques.
B. Speak just to the current issue. A reference to how long it's been working, is fine, yet presents little valuable information to an expert seeking to refine their response.
C. There are four major areas that represent nearly 99% of all printer issues. They are:
1. Ink issues. This usually happens when the cartridges are changed. It's vital to do a clean and calibrate, just after installing new cartridges. Try that first, and then a test page.
2. Paper jam issues. Visually inspect the inside of your printer, and focus on little slices of paper(comes from those papers with perforations).
3. Communications errors. Check all the cables for secure connection(they do come out sometimes, for no reason). Also, make sure that you have the most current drivers from the makers website.
4. Actual Print output issues. These are across the board, and without all the first 3 issues resolved, would simply add to your potential problem.
Most of the experts are good at what they do, and are willing to help you out. Help them, Helpya.
And, also, it's part of the experts program here to get constructive feedback from all helpees. Please consider adding your comments to the problems, so that we can all learn more about how to be better experts.
Thank you for your courtesy.
Patrick the Printer Man
IB4G2008 Fixya Wizard
on Apr 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Replaced ink cartridges in Lexmark Z52. Noe ink
There should be a clean program that you can run.
First restart windows, then run the clean program,
see if this helps, try and print. If you need more help
re-post what you did and still have a problem.
Feb 05, 2010 | Lexmark Color JetPrinter Z52 InkJet
I have Lexmark z52 which doesn't print. The light flashes. I unplug and plug it back. It still doesn't work.
try to unplug the printer and wait a few second and plug it again..
if the problem still persist
May 18, 2009 | Lexmark Color JetPrinter Z52 InkJet
Inkjet download problem
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Lexmark JetPrinter Z25 InkJet Color...
Problem installing lexmark 2650 on toshiba a 30 satellite
did you add a printer onto the computer control panel
did you down load the printer driver from the manufacturers web page downloads
Jun 03, 2017 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Lexmark z52 problem
got similar problem
mine flashes 12 times and doesnt print at all
when i remove the black cartridge, everything seems to be working fine
think my problem got smth to do with the black cartridge but i never had a problem like this before
plz help
grtz
Apr 10, 2008 | Lexmark Color JetPrinter Z52 InkJet
Lexmark JetPrinter Z25 InkJet Color Printer Logo
37 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
