Question about Frigidaire FDE336RE Dryer
Not heating Hello got a fridgeaire electric dryer not heating everything eles working fine.
I had the same problem on Frigidaire and Maytag electric dryers, with manual, not digital controls, and it turned out to be a bad electrical connection (i.e., one of the three wires from the power cord where it connected to the back of the dryer had come lose and shorted out). Be sure to unplug the dryer then check the power cord plug and connections, which should be easily accessible at the back of the unit on the upper left (you will have to remove the protective cover plate(s), which is held on by a screw). This would also be a good time to see if the circuit breaker has been tripped, which would indicate a short somewhere. If it has, I would move it to the off position until you've checked the electrical connections on the dryer. The heating element runs on 220 volts while the motor and everything else runs on 110 volts, which indicates a bad connection for the 220/240 circuit. You may need a replacement power cord if it's damaged (available at local hardware stores, just make sure it's for a dryer; they're different than other appliances) and/or a new connecting block, if it's damaged (you will likely have to order this part). You also may need new connecting hardware, so check to make sure the existing nuts are reusable. It's a simple fix that doesn't take much skill, just be sure to unplug the unit before doing any work, replace the connections exactly as on the original, and don't forget to reset the breaker if it was tripped or you switched it off. If that doesn't fix it, it may be the heating element, which is a whole other story. Good luck.
Posted on Mar 15, 2009
The dryer wont heat up the clothes dont get dry everything eles works on it the drum turns ok the timer works also it just wont dry the clothes
Hello,Sam
The usual reason a dryer will heat yet not dry the clothes is going to be a air flow problem. What ya need to check is for a blocked vent and or lint build up in the blower assambly.
By far though a leading cause of that on Maytag dryers is a broken blower wheel and therefore no warm air is being drawnthrough the clothes,to check that remove the front panel and the front drum support and in the lower left corner will be the blower asm. check to see if it moves free and doesnt seem to be attached to the motor shaft.
GENE
Sep 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
Estate by Whirlpool Dryer DWSR-ELE-2406028-FM54 doesn't heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 20, 2011 | Dryers
Kenmore Electric Dryer , 700 series, MOD 64722400 , SER MR4136705 , Type DWJR-ELE-2406028-FM64 . Dryer is not heating, checked fuse it's fine, cleaned every nook and cranny with a swifter duster and...
Hi.
Be sure that you have checked the thermal fuse. The part is tested using a multimeter set on Ohms (impedance). Remove the fuse from dryer and read impedance touching the fuse contacts with the two multimeter probes. If impedance is Ohm infinity (open), then the fuse is bad.
If the fuse is OK because tested good or replaced, then the problem is either one of the three thermostats located in the heating group, or the heating element. All parts are tested similarly to what described for the thermal fuse. If any of the parts read open (infinity), then the part is faulty. After finding the defective part remove all the lint from heating assembly and air duct. The lint causes overheating and blows thermostats, fuse or element.
Regards.
Ginko
Jul 14, 2011 | Kenmore 64722 Electric Dryer
I have a maytag dryer (dwsr-ele-2406026-fm54) and all of a sudden it will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 16, 2010 | Dryers
Dryer tumbling but no heat
Hello
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer has power, motor runs, Won't heat. Kenmore Dryer Mod# 118 C68932792 Serial # MJ 3787524 Type - C007 ELE 2386824 EH54
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 10, 2010 | Kenmore Dryers
Our gas dryer from fridgeaire is not heating and will pause to a stop after a while. Is there a way to address problem with calling in a technician.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 06, 2010 | Dryers
I have a type DHZN-ELE-2406024-EL54 model
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryer works but no heat
heating element needs replacement
Oct 30, 2009 | Dryers
Dryers Logo
154 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Electrolux
Electrolux
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
