Question about Cameras
I haved a lens error on my Canon Powershot A570. It is not yet one year old.
    Genius:
  • 1,689 Answers
Hi morelle, thank you for using fixya.
the lens of your camera may have been stuck or a part of the actual assembly is stuck. When you shake the camera without the battery and a memory card, do you have a loose part inside?
also nudging the lens while the camera is on may also help. but if it does not move a bit, better get the camera to the vendor or a Canon service center and have the warranty running to get the camera repaired.
Posted on Jan 06, 2009
  • 4,472 Answers
Http://www.usa.canon.com/consumer/controller?act=ServiceLocatorAct&fcategoryid=221&modelid=14905
Then the camera is still under warranty follow this link and contact the nearest service center to have it serviced under warranty. If you have any other questions please let me know. Also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
  • Lee A.
    Lee A. Jan 06, 2009
    Do not do any of the steps described below. Obviously the expert does not know that you never work on a camera that is still under warranty.
    Thanks again,
    Lee
    President:
  • 2,110 Answers
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
When I open my Canon A570 camera, The lens stuck, and it says on the screen :"lens errror - restart camera". What can I do? Thanks, Nati.
This message ' lens error - restart camera ' is usually shown under the following condition.
An error was detected when the lens was in motion and the power has been automatically turned off.This error can occur while you hold the lens when it is in motion or you operate it in a location with excessive dust or sand in the air.Try turning the power back on, and resume shooting or playback.If this message continues to display it shows a problem with the lens and you have to open and repair it which I would not prefer as it can affect the fine mechanics inside the camera.You can contact the Canon Customer Support Help Desk from the following link. ( http://www.usa.canon.com/cusa/consumer?pageKeyCode=requestRepair ).Your valuable feedback would be appreciated if satisfied with my solution.Thank you.
Jun 09, 2011 | Canon PowerShot A570 IS Digital Camera
Camera showing lens error restart camera every time I switch it on
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Jul 27, 2010 | Canon PowerShot A570 IS Digital Camera
Lens error restart camera SD750
somebody saying under warranty
http://www.digitalcamera-hq.com/digital-cameras/canon-powershot-a570is_question.html?qid=12688
May 30, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon A570IS lens frozen half way-no power
I have a a570 IS that the lense locked out on. fixing it was going to be the same price as buying new, so I took mine apart and after two tries, i fixed it. I would be willing to take a look at it for a heck of a lot cheaper than Canon can if your willing.
May 22, 2009 | Canon PowerShot A570 IS Digital Camera
I try to turn the camera on it says lens error restart camera
try to smack the camera with your hand couple of times.or tap all the sides of the camera with your hand .if the lens is moved it will get adjusted and the error will go if still the same error then the lens needs replacement. for this for reparing estimates cost  of camera
http://www.advancecamera.com/repair
                     the link will help you to get the device repaired and serviced
·                                 Free estimates.
·                                 Reasonable rates.
·                                 Fast, friendly, and personal service.
·                                 Top quality repairs.
·                                 Advance Camera 1 Year Warranty
Mar 14, 2009 | Canon PowerShot A570 IS Digital Camera
Lens error and will not retract
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 09, 2008 | Canon PowerShot A570 IS Digital Camera
Lens error
Hello folks,
I hate to be the bearer or bad tidings but you have all suffered from what is probably the number one affliction of digital cameras - the deadly child drop :-(
In almost all cases the camera has to be sent in for service when this happens. Obstructions (by hands, restrictive pockets, or even pocketbooks with little extra space in them) are very common causes of lens errors as is drops, and all cause damage that needs to be repaired at the Service Center.
Even worse, this type of damage is not covered under your warranty even when you are still within your 12 month warranty period. Therefore there will be a charge.
The good news is that the charge is less than the cost of a new camera, and that for certain camera models below the A560, you may qualify to upgrade to this model for less than the repair cost. Call Canon at 1-800-828-4040 for your options. Good luck.
Hope this helps.
Sincerely,
HeavyDLB
Apr 28, 2008 | Canon PowerShot A570 IS Digital Camera
Cameras Logo
205 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
