Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Blue Convergence How do you access the service menu to adjust a blue color convergence for Mitsubishi WS-55513 55 in. Rear Projection HDTV Television Convergence
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
Go to main menu , selet advance setting , after that there is another menu where u going to find a convergence ajustment , select convergence adjustment , than choise blue , than after u access to blue color press the audio boton to do the blue , if u can't muve the blue color u going to have a repair service maybe ur stk or convergence ic are bad
Posted on Jan 16, 2009
I have a 62 inch mitsubishi ws-65413 and the color comes in the goes out. blue and yellow are in more. what is the problem ?
if colors look skewed and come and go----next time enter the convergence menu on the set and call up advanced---a grid of lines should appear---if skewed when set bad (lines should be yellow) you have a common issue---convergence----the model indicated uses two stk-394-250 chips and both would have to be replaced.
Aug 26, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-48511: can't adjust blue convergence
I am guessing that you did the convergence menu 1.CONVERGENCE MENU "MENU 2159, 4 FINE, 5 COARSE, 6 MISC
2. There are Fuses F9A04 & 05 that may be open.
3. If you do the self test do you come up with 2-2?
4. Self-test on threads here or at ctechnicians.com
5. If one or both fuses open you will need to change convergence amps and parts.(Kit)
Dec 23, 2007 | Mitsubishi WS-55711 55" Rear Projection...
My 55" WS Mitsubishi projection
The convergence is out, and the convergence ICs' would have to be canged on convergence board, and you are looking a a repair bill between 300-400, and if it was mine for the year that it is I would not lay any money into it, Just buy a new LCD, take care.
Aug 16, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
It is having double image. The second image is to the right with red color.
Sounds like a convergence problem. See if you can adjust the customer convergence controls (in the menu).
If you can not adjust one or both the colors than your convergence amp is toast!
Mar 06, 2011 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi Medallion 1080 WS-55413 - colors not aligned
There is no "reset" as the set has in the customer and tech menus ways to attempt to manually adjust this.
under convergence in the customer menu select advanced and follow the instructions on the screen.
If Red or Blue or Green are skewed and will not adjust it means one of the two STK-394-250 CONVERGENCE chips this set uses is bad.
Depending on where you buy them they will range in price from about 12 dollars each to nearly 35 dollars each.
Let me know what you find; this may or may not be a do it yourself repair as some real expertise is required to correctly get at and replace the chips.
SD TECH
May 11, 2010 | Mitsubishi WS-55413 55" Rear Projection...
How to reset convergence? on mitsubishi ws 55511, has a shadow colored blue or yellow
There is an option in the user menu on the tv. Using either the remote or control panel on the front of the tv, press MENU then select SETUP. After you choose SETUP go to the 3rd column with the 3 icons. Here you can adjust the red or blue color or reset the convergence back to factory default.
After a few years the set will begin to show increasing problems with the convergence settings. When you can no longer adjust either red or blue horizontally or vertically an IC replacement will be needed. Your set uses (1) SANYO stk393-110 and you want to make sure it's SANYO and not a knock off brand as those usually fail prematurely.
Jan 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi Convergence issue
If the screen is out of focus you probably need to adjust the focus on the focus block it is usually located behind the front grill, there are 6 adjustment screws on this block, leave the screen controls along just adjust the red, green, and blue focus screws. When converging a set everything is converged to the green, the blue and red are suppose to come to the green.
Sep 02, 2009 | Mitsubishi WS-65311 65" Rear Projection...
Problem with color
Good Day, and;
Try this first:
TO RESET THE CONVERGENCE EEPROM, PRESS "MENU 0359" TO ENTER THE CONVERGENCE MENU THEN "8970". If not the TV may have a circuit, come back.
Good Luck, Big Irish.
Apr 14, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
215 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
