Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I have a 32 inch samsung lcd tv all of a sudden these horizontal lines of red dots appeared all over the screen please help can i be fixed the tv is only 18 months old
  • 23 more comments
  • DAVID FOX May 27, 2007
    it happens on all sources but not on the menue screen
  • Anonymous Nov 03, 2007
    I have seen the same on my Philips 32PFL5332D 32" LCD. It appeared on the regular TV and HDMI input from DVD and the set up menus. I shut it off and unplugged it for a few seconds. It went away after I plugged it back in and turned it back on. I am not sure if it has to do with a build up of static charge. I have heard LCD TVs are prone to being affected by static charge.
    Can anybody confirm this?
  • Anonymous Nov 09, 2007
    We are having exactly same problem. We have turned the tv off, sky off, dvd off and still happening. Teletext however works perfect
  • tim graham Dec 06, 2007
    i also have the same problem. my tv is only 19 months old.
    could they all come from the same batch,i ask this because told manafacture gaurante is only 12 months.may be able to push for refund!!!
    tel 07973727505
  • lori11 Dec 09, 2007
    I just bought a Polaroid 32" lcd three weeks ago and today I turn it on and there's lines up and down & no picture just sound. Tried unplugging it and turning it back on and still the same. Anyone know what is wrong, and is it worth fixing
  • Blackstar1 Dec 10, 2007
    I have a Samsung 32 inch model LNS3241D, 18 months old and all of the sudden multicolor horizontal lines started appearing. More and more untill 80% of the screen was covered. I could still see the channel picture through these lines, but, the lines were there. When I turned it off, let it cool down, the lines were no longer there. Within 1-2 minutes, they slowly returned. Can anyone help, much appreciated.
  • Anonymous Dec 13, 2007
    i just got my tv and i conected my hd set top box to the tv turned it on and at a certain coulour red dot apear i dont know what it is cause it doesnt apear on normal tv
  • Anonymous Jan 07, 2008
    I've had exactly this problem with this Samsung TV. I called Samsung who were worse than useless. I tried taking it to a repair shop and was quoted £300 -£350 to fix it. With brand new versions costing around £450 it's not worth it. All I can recommend is never buying a Samsung again and telling everyone you know to avoid them.
  • Anonymous Jan 09, 2008
    I have a similar problem. It affects all sources, a bouncing vertical red dot appears when the set has been on for a while. The red dot appears about 8" in from the left. My set is still under warranty however and I will contact the store re this issue. Otherwise brilliant TV.
  • mrsoul027 Feb 08, 2008
    Same problem exactly... started with one line of coloured horizontal lines and now it's two... no one has answers?? I have the 40 inch version
  • Sunsprite May 03, 2008
    I have coloured horizontal lines across my daughter's LCD,it's a year old and hardly used so disappointed to have it Not working.
  • sarahtullay May 04, 2008
    on pictures there are red dots all over and theres red lines going across the screen
  • grinch2000 Jun 10, 2008
    40 inch same problem, red line on left of screen, red dots on screen, 6 months old should be under warranty but going to be a pain to find receipts etc.
  • idc1966 Jul 15, 2008
    I have a simmilar problem, but my dots are blue all over the picture, tv engineers have no idea what is causing this, as no imformation is available
  • idc1966 Jul 17, 2008
    Took television to repair engineer, he advises me that the set is not repairable, and samsung are aware of the problem, which is a board fault and they have discontinued the set, and there is no parts available for the set, told me to bin it or sell it to someone who might require a screen.
  • Anonymous Sep 15, 2008
    Hi, I have an LN-R408D with little random red lines. They are very thin and come up on darker spots of the screen. Best Buy just came and looked at it and said he'd order the parts...but you say they are no longer avialable to fix these older TV's? What is the part number that causes this or at least what's it called?
  • river9650 Sep 16, 2008
    i have a samsung hd tv 42 inch. they are so wrong not to help us with this issue my dots are white and they started just afew now have grown to half the screen.repair coming cod if you can believe that why hasnt samsung execs stepped in to help us. my tv is only 14 months old the bulb went out the 3rd month i had they are not cheap mj tampa fl
  • icemonster Jan 04, 2009
    I have a similar problem. samsung 40" LCD LNS4095D, white, red and green flickering dots, mostly white. Happened 14 months after i purchased,samsung, would not help because it was 2 months out of warranty. Cannot find info anywhere about the problem, it happens with al inputs. If i view the menu without any inputs, the menu shows up crystal clear. Its not a pixel problem but some kind of signal or processing problem. Don't buy samsung. Crappy company, won't address the problem.
  • leskwolfe Jan 15, 2009
    My Samsung 42 - now has almost a half screen of horizontal lines...
    they have grown exponentially over the past 2 months.
    I think this is really terrible - and something we should post on the SAMSUNG site!
  • khibdwb Apr 01, 2009
    Just encountered the same problem this week...exactly 20 days after my one year warranty expired!
    Where can I sign up to be a part of the class action lawsuit?
  • ksyphrett Apr 17, 2009
    I have a 15 month old 47" LG LCD HD. It developed red line on left side and anything that would ordinarily be black is now red. LG customer service told me they have never heard of this problem and I am on my own since it is now out of warranty. This is the 2nd LG I have owned that has not last more than 2 years without having a problem.
  • Anonymous Mar 15, 2014
    I have LG 21 CRT and having problem of white horizontal line about 3/4 mm on the top of screen. other everything ok. from these lines picture seems became cartoon faced. the line appears on 2cm below from top. please help.
    my 32 inch ld led tv has a horizontal red lines
  • Anonymous Mar 20, 2014
    Screen is red
  • Aravind M
    Aravind M Mar 09, 2019
    Yes I have the same problem...what do? villas in Kanjikuzhy
I unplugged the TV and now the picture is back.I read that the LCD's are vunerable to static build up so unless my daughter is using her TV I unplug it.
I was thinking about getting a large LCD for the family room but I'm not going to until they improve on this technology.
Good luck to everyone!.
Cheers.
Posted on May 08, 2008
It is probably due to the signal being corupted before it reaches the screen, due to inteference in the cable. Try to swap cable, or get all power cords as far away from it as possible.
Posted on May 06, 2008
I had a mass/earth cut and it does that on my screen. What I do is I plug it where the electricity is ok
Posted on Mar 03, 2008
If you run your cable through a video switcher it will distort the signal.
Posted on Oct 22, 2007
2 Suggested Answers
SOURCE:
  • 10 Answers
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Posted on May 23, 2009
Red dots samsung plasma
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 04, 2016 | Samsung Televison & Video
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
? 2:47
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Jul 08, 2010 | Samsung LE32A457 32 in. LCD TV
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
Horizontal Lines on a LN-S3241D
i'm sorry to say It's most likely broken. I think the LCD screen is going. Try calling up Samsung to see if they can fix it or repair it for cheap. Good Luck.
Aug 29, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
BLOWN PIXELS
Usually not but in some cases gently massageing the dot(tv turned on or off try both) with your finger may work (dont push too hard)
or put on a channel with static and try
your chances are slim though this is usually a defect in the lcd technology and most manufactures only warranty it for 5-7 stuck pixels
Jan 05, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
12,634 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
