Question about HP Computers & Internet
Moniyor fault my hp VS19X monitor has just shut down and wont power back up. is it fixable or is a new one needed
  • 233 Answers
How do you know the monitor is the problem? Try your computer with a different good monitor. If it has the same problem then the computer is at fault. If it works correctly then the monitor is at fault. Is this a CRT or LCD monitor? If it is a CRT monitor (with a big picture tube like old TVs) it would probably not be worth repairing. You can buy used ones pretty cheap. If it is a flat LCD monitor you would need to get a repair estimate and weigh that against the cost of a new one. Anything can be fixed but if repairs are more than new what would be the point?
Posted on Jan 07, 2009
Monitor keeps shutting off and will not come back on unless i shut down the tower....what is wrong with the monitor, do i have to get another one?
With a monitor there a a number of things that may be causing the problem.
Firstly - if you unplug the monitor cable from the computer and start the monitor does it work: (should turn on and give an error message (no video input found or something similar). In this case the monitor is good and something is wrong with the computer.
If the monitor does not work then the monitor is at fault and it is likely the inverter is tripping the power out. that means a component is shorting or it is burnt out. These can be replaced but you are getting close to the cost of a new monitor to replace them.
Please let me know if the monitor is the faulty item. If it is not we can move onto the computer to see what is at fault or I can give you more details about repairing a monitor.
Mar 07, 2011 | HP Compaq W17q Wide LCD Monitor
Screen has no picture. just a gray hue, is it fixable? its 2-3 yrs old. if it has a fuse would that be the fix?
No Fuse...
Above is your manual.
All things are fixable it simply depends on if you wish to spend the $$ to repair.
In my opinion, after that long, the monitor should be replaced, as even if repaired it would still have old components in it, and we find, that once a unit faults, it will usually fail again inside of a year, according to stats too.
So you would be better putting any money for a repair into a new monitor with a warranty...
Aug 01, 2010 | HP W2007 LCD Monitor
HP DV928US When battery in or charger plugged in
fails battery out so leave it out they love to short.
so when it fails test 2 is, hit the F10 or ESC key promptee
went it fails to boot, check BIOS key first, if BIOS fails.
be more clear.
what does it do when it wont turn on.
BIOS dead. screen 100% dead, and not even text
BIOS works even with HDD and DVD drive pulled.
that is the acid test on PCs.
the screen must say, hit F10? or ESC to enter setup, means HP BIOS. it must or power is no good. get a new power pack
the shut down tell me lost power, that can be the power pack 19vdc
or the jack at the mobo if failing to said pack.
try side pressure on that jack if at anytime the power button fails.
it self shuts down, I got that but lets fix , cant boot first.
that is how to fix this.
power on failures, are you saying the power key fails. some times
and the fan does not run every time.?
this old LT uses CCFL back lamps.
that love to fail. so when it shut down did the fan die.
did the HDD stop spinning ear to bottom? if not the CCFL is failing.
using and external monitor proves this every time,
do the flash light trick?
Aug 29, 2017 | HP Pavilion dv6928us Notebook
My laptop monitor keep shutting down....
Check the display power settings in Control Panel.
Oct 04, 2009 | HP Pavilion dv4000 Notebook
Monitor has dark wavy lines on edges
Well... sure it fixable, but it is going to cost you a bundles... Since you own this monitor for about 10 yrs. It's time for you to give yourself a new LCD monitor for the Holidays... :) Have nice day!
Oct 13, 2008 | HP Computers & Internet
Monitor shuts down unexpectedly, can't bring it back up
Please verify your monitor screen saver options.there u can find power selecting that button u need to change turn off monitor option into never.then your monitor never shuts down unexpectedly.
Sep 14, 2008 | HP Computers & Internet
Faulty LCD Monitor ?
off hand it sounds like a power supply issue. sometimes fixable sometimes not.
Aug 26, 2008 | Scanport Computers & Internet
BenQ FP 731 17" black LCD
It sound like power on the monitor if it is this what you need to do.
Change the 2SC5707 transistors and electrolytic caps in the inverter
section. Also check the 3A picofuse, and resolder all transformer
pins. Are buy a new inverter board,this brand of moniyor is a Dell monitor.
Hope this help you.
Aug 24, 2008 | BenQ FP731 - 17" LCD Monitor
My hp lcd monitor won't power up
wat is the model n#. of your hp LCD?
just check the supply section board check the fuse all resistor and capacitor.
just use the multitester if u check all parts..
Feb 22, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Computers & Internet Logo
94 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
