Question about Compaq Presario M2000 Notebook
Left side of monitor screen has smudge
Approx one inch verticle stripe of my montior looks like black ink smudge all the way from top to bottom
I run on Windows XP, pack3 and I use a CRT ViewSonic EF70 ... 17 inches The screen is not filled completely with the image from Microsoft Internet Explorer, nor with Outlook Express .... there is about 3...
two things you can do, first right click on your windows screen and look for "settings" this will open a dialog box where you can set the screen resolution. Set it lower and see if your screen is now filled. if that doesn't work go into the monitor setup (buttons on the bottom or side of the monitor) and try to set the verticle and horizontal size, since its only 3/4 of an inch you should be able to stretch the screen to fill up the space.
Mar 11, 2011 | ViewSonic E70f 17" CRT Monitor
Strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Jun 16, 2009 | Philips 200P4 (Silver/White) 20.1 in. Flat...
I have a 42' LG plasma that has now has a 1 1/2 inch verticle stripe on the right side. It used to come and go but now rarely goes away. Any ideas?
I believe that this could be a type of "burn in". If you watch anything with a black stripe on the sides or bottom of the screen often, then this could be the problem. My suggestion is to watch things that have no black side bars for a while (>week) and see if this eliminates the problem.
Good Luck!!
Jun 11, 2009 | LG 42PC3D 42 in. Plasma Television
HD Pavillion Media CenterDv8225nr Notebood Pc. Verticle stripes
I would try a couple of things. First and cheapest way is to try and update your driver. If that does not work, then try to remove and reseat your memory card(s), and if all else fails you will need to buy a new graphics card approx 75 to 150 depending on how good you want to go.
Feb 04, 2009 | IBM ThinkPad T21 Notebook
Magnavox 42MF7000/17 Green Stripes Pixel down section of display
Possible Defect in programing. Call Manufacturer for possible support in Updating Firmware.
Jan 18, 2009 | Philips Magnavox 42MF521D/37 Television
Darker fatter letters every 2 inches apart from top to bottom
it is called phase you can attempt to let the lcd monitor auto set or you can disconnect the power over night then plug in and then do not auto set this default usually seems best some times
Nov 29, 2008 | Proview PL926WBi 19" LCD Monitor
Streaks make letters fatter every 2 inches apart across screen
this is called phase it can be set auto by the button or you can disconnect the power and next day reconnect and leave it in default which can be better than letting the monitor try to set the phase.
Compaq Presario M2000 Notebook Logo
189 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
