SOURCE: My Canon Pixma MP220 is
Same thing happened to my MP220. U051 chk Blk and Colour. I got my colour one replaced as there was an electrical fault in it. So the solution is to replace whichever one has the electrical fault or both and it works just fine. Refilling only works for a certain number of times. 4 or 5 at most and mine only lasted 1, so not always successful.
SOURCE: Ink Error "Check Ink, U051, BLK COL"
power off
press hold red button
power on hold button
release red button twice
=beep=
all done !
SOURCE: MESSAGE 'CHECK INK U051 BLK COL'
just hold down the stop reset button for 10 seconds it will bypass the ink counter
SOURCE: canon mx318 u051
Try to press and hold the resume button for 5 seconds.If this not help you need to replace the ink cartridges.
SOURCE: Showing Check Ink U051 COL. Have removed the
Hi there
For troubleshooting purposes,
Perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Testimonial: "Thanks for the help - solved the problem straight away."
