Question about Panasonic NN-S761 1300 Watts Microwave Oven
Smells like rubber burning after turning oven on
Smells like and electrical problem, like rubber burning
Microwave does not "heat" and smells when turned on.
calling the company will be the best suggestion because if the smell is like burning plastic, it will be a problem electrically
Mar 21, 2016 | Microwave Ovens
What to do when oven smells like burning plastic
new ovens do have a certian amount of "burn in" to do when there new best to heat up and cool off oven several times before actuall food use to remove any construction solvents and "cure" all the materials inside
also ck to make sure you removed all the shipping packing sometimes this gets left inside by accedent and smells something horrible when heated ( caution :: Foam degrades to cyanide deadly gas when heated!!!!)
Sep 08, 2014 | Microwave Ovens
Emerson microwave oven MW8102SS smells electric burn while heating food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 '
Jun 07, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave oven MH8150XJT0 is NOT HEATING -- MAKING LOUD, DEEP HUMMING SOUND -- SMELLS LIKE ELECTRICAL BURNING
Basic Microwave Oven TroubleshootingTips
heatman101
Apr 02, 2011 | Whirlpool MH8150XJ Microwave Oven
I have a general electric microwave it works but will not heat food and when i turn it on it smells like something is burning
  1. inspect plastic coupling beneath tray.
  2. Check ring and roller assembly for misalignment or debris.
  3. Make sure that tray is sitting properly on turning mechanism.
  4. If carousel motor is broken, contact a service technician.
    hope this helps you
Dec 30, 2009 | General Electric Microwave Oven
Won't bake bread
you have an electric short and wires and wire covers are probally burnt. do not use take it in for repairs or replacement.
Apr 26, 2009 | Microwave Ovens
Microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 25, 2009 | Kenmore 64663 Microwave Oven
When I press the start button it smells like it is burning
if the is a convection model then the covection coill will smell that way if there is a geese build up and should be ok to use. however you should only smell that if you are using the convection mode.
Nov 27, 2008 | Panasonic NN-S954WF Microwave Oven
Burn at bottom of microwave
First try cleaning the burned mark off. Dip a scrubber in lemon juice and sprinkle salt on it; this is also great for burned coffee pots. The smell can be gotten rid of this way: Boil lemon peel in water, then put the water in a spray bottle. Not only will it make your microwave smell fresh but the lemon oil will make it easier to clean. If it still smells of burning rubber, take the back off and inspect the wiring. IF you see burned wiring, please do yourself a favor and replace the microwave!
Microwaves work by making the molecules in food get "excited"-they move more-meaning, if there IS rubber burning, then there will be minute molecules of rubber in your food, which is BAD for your immune system. If it's just burned chocolate, though, it is harmless unless you are allergic.
Apr 03, 2008 | Danby DMW1400 Microwave Oven
Panasonic NN-S761 1300 Watts Microwave Oven Logo
187 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
